Valve cover leaking from bolt/rubber washer
Did you verify the valve cover gasket is fine around that area of the bolt as well?
Maybe just apply small amount of RTV/sealant if you really did replace with new hardware already.
Goodluck
Goodluck
You need to replace the gasket. It's letting oil through, which is going up the bolt, and out from under the head.
I still have the original gasket on my nearly 15 year old car. Left undisturbed the gasket adheres to the head and cover and maintains a seal even as the gasket shrinks and the fasteners loosen.
Since you have a leak you might try tightening all the fasteners. Caution, the correct torque is only 31 inch pounds which is almost nothing. Going beyond this risks cracking the cover.
That has nothing to do with the valve cover sealing.
ethan169
13
Jan 17, 2012 02:28 PM
jkboggs
Mar 22, 2008 10:42 AM
SlowCar
Dec 30, 2005 04:07 PM
mybada
Jul 7, 2005 09:10 AM
