Tephra V2 XML Help!
Old Oct 20, 2017, 07:07 PM
Chuche831's Avatar
Tephra V2 XML Help!
Hello,
Im a new fellow evo x forums member. I got my car tuned with a tephra v2 map and im in a situation where I need to pass smog relatively soon, which cant be done on my current tune. Im trying to get a hold of the xml definition for ROM ID 55570206 to be able to open my ROM in ecuflash, save it, and upload my stock map in order to pass smog then revert back to my pro tune. Was wondering if any of you can help me gather this definiton?
Thanks a lot in advance for anyone who can help me out!
Old Oct 20, 2017, 11:16 PM
4b11slayer's Avatar
You can pass smog with a tune. Just need to.make sure your obd2 readiness monitors are all.completed. what ever monitors apply.
Old Oct 20, 2017, 11:22 PM
Chuche831's Avatar
The problem is I got tuned with a test pipe so my rear o2 sensor was turned off and also my cat monitor is not ready. being from CA thats a fail./: So my only hope is being able to get a hold lf that xml to open the map and enable the rear o2 or use the xml to be able to re-flash the map after flashing the stock tune to get the smog check done.
Old Oct 21, 2017, 06:58 AM
4b11slayer's Avatar
Ah i see. Have you downloaded all the tephra v2 xmls? And stored them in rommettadata?
Old Oct 21, 2017, 08:22 AM
Chuche831's Avatar
The map got uploaded by my tuner so I do not have the tephra xml files and ive been looking through all the related threads on here and in the evo x forums see if anyone can help out but no luck. Thats why i posted this in hopes that someone has the xml i need.
Old Oct 21, 2017, 12:02 PM
4b11slayer's Avatar
you need to find the tephra v2 thread on here.
Download and save all xmls to
local disk c, program file x86, open ecu, ecu flash, rommetadata, roms, mitsubishi, evo
Old Oct 21, 2017, 12:34 PM
Chuche831's Avatar
I have gone through every post and every page on the tephra v2 thread that he started. I also went to tephra’s website and there is no download link or copy of any xml for my ROM. He only provides them for the v1. I went on golden evo’s website aswell and he only provides xml’s for the stock ROM’s. Not sure if I am required to re-purchase it to gain access to my map? 👎🏼
evo8vz
Jul 28, 2016 09:47 PM
3gevoclipse
Jan 31, 2016 10:07 AM
sbn1979
Jan 28, 2010 10:59 AM
zheng0416288390
Oct 1, 2009 07:26 AM
Quick Reply: Tephra V2 XML Help!
