MAP Cast V-Band Turbo Kit - PTE5858
alpinaturbo (Nov 3, 2017)
This is a long time coming and frankly I could have probably waited longer but at this point I feel like this has taken way too long already.
I picked up a MAP Cast V-band turbo kit back in November 2016. I was also going through a motor build at the same time and long story short is that the motor build took forever and it took until August of this year to get my car back in my driveway.
Since then I've had a bunch of little issues that I have had to deal with to get the car working correctly overall. Nothing to do with the turbo kit and every thing to do with the build. I'm still working through some issues but I didn't want to continue waiting to make this thread.
If you want to follow my build thread, take a look here: https://www.evolutionm.net/forums/pr...e-build-s.html
So here are the specs of everything:
MAP cast v-band Turbo kit:
PTE5858 turbo v-band in/out and .82 stainless steel exhaust housing
MAP stainless cast v-band exhaust manifold
MAP downpipe non-dumptube version
Turbosmart 14psi external wastegate
Depo aluminum upper intercooler pipe (used in place of kit SS pipe)
MAP intake custom wrinkle black plus added -10AN and -6AN breather fittings
AEM 7.5” x 5.125 air filter (upgrade from kit filter)
Since I track the car I also had custom inconel heat shields made for the exhaust manifold, turbocharger and downpipe. They are a work of art and worth every penny. See photos at the bottom of this thread.
RED Darton sleeved block
Carrillo Pro-H Rods
CP 86.5mm 10:1 CR pistons
CP 9310 upgraded wrist pins
OEM crank
MAP high capacity oil pan (+1.5qt)
MAP oil cooler kit
Kelford 214-b cams
Kelford valve springs
Driven Fab billet mivec exhaust housing
Supertech stock size intake / exhaust valves
GSC viton valve stem seals
GSC manganese valve guides
ARP head studs
AGP 3.5” intercooler
OEM lower intercooler pipe
Tial QRJ bov 1.5psi spring
Grimmspeed 3port
Turbohoses.com -3AN SS vacuum lines (Wastegate, turbo, BCS)
Magnaflow 3” catback (added Vibrant mini muffler in mid pipe)
Ultimate racing mini muffler test pipe
Mighty Mouse sealed catch can breather setup
ID 1300cc injectors
Radium fuel pump hanger (Walbro 255 fuel pump)
Radium surge tank (Walbro 450 fuel pump)
Blueflex Flex Fuel ECA
Easy Performance fuel pump controller (0-5v MAP reference)
Custom inline SS fuel filter
ACT HDSS clutch
Current power...
Caveat, this is low timing and low boost. I'm still working through the issues the build has had and still working through the tuning.
That said, I think it's making phenomenal power for the low boost and low timing I'm currently running. I have no doubt this setup will make over 600whp easily and I will update this thread when that hopefully happens. It's hard to tell from this single gear pull but the turbo is more responsive on the street than I ever imagined it would be.
Other caveat, I maxed out my ID1300s and have ordered a set of ID1700s.
Blue plots are a break-in pull at 19-20 psi.
Red plots are current tune, maxed out ID1300s and 25-24psi.
E79 fuel
Here is the datalog of the above: https://datazap.me/u/razorlab/rcwots...zoom=1110-1556
The kit overall is well made. I had some small fitment issues at the beginning but got everything working. The cast manifold is a tank and I have no doubts it will last longer than the car.
Photos:
Engine bay
Living in California. I worked hard to hide all the catch can breather lines
With the engine cover on you can't even tell the car has a catch can and the can itself is hidden under the intake
Some photos of the custom inconel heat shielding
Carrillo Pro-H Rods
OEM crank
MAP oil cooler kit
Kelford 214-b cams
ARP head studs
Grimmspeed 3port
ID 1300cc injectors
ACT HDSS clutch
Current power...
E79 fuel
Photos:
Engine bay
Great results!! Were your heat shields done in MN ? My setup is currently wrapped but that looks so much better. Whats your opinion on heat reduction resulting from installing these
http://www.atpwrap.com/home.html
-Kevin
He bought this setup last year, before those turbos came out.
