Ideal Location for Hands-Free Mic
I've got the headunit per this:
https://www.evolutionm.net/forums/ev...ac-set-up.html
But i've never bothered routing a mic because I figured the car was too noisy. I'm willing to give it a try, but I'm wondering where exactly it should go? On the a-pillar? Steering column? Somewhere near the map lights? Anyone got a good solution for this to pick up voice without too much road noise?
i put mine on the steering column
its mount came with a 3m double sided adhesive. I didn't want to route the wire through the actual cover because I take **** apart often, but you could if you wanted to for a cleaner look. Pics incoming
damn i need to clean my interior lol
it came with my pioneer deck, ya I haven't gotten any complaints. My interior is noisy as hell too.
another viable spot would be on the underside of the plastic surround above the factory gauge cluster, that would require drilling a hole to run the cable though, which i didn't want to do. As you can see i already have too many left over holes from previous gadgets.
