Evo 7 turns on all 3 acd lights
i have a evolution 7
my car turns on all three lights tarmac,gravel,snow
The problem im facing is that sometimes it turns on after driving 500 yards and than they dont turn on for days and car drives smooth
i have checked my pump and its working
i have noticed the oil reservoir bottle in the trunk keeps on changing oil level
at times it is at center and than it is filled till cap
what i do is i turn the switch on press the accelator and the oil will just go down and the acd lights will be normal
what can be the possible issue
your pump is probably on its way out. As the temps rise you will get the 3 lights more often. Time for an overhaul.
just service the pump and bleed the system
the pump needs to be opened, cleaned from corrosion, some parts changed, seals changed and then you need to put it on the car and using a mut III tool or a custom pump tool the system needs to be bled from air trapped in the system.
check the vid in my sig.
06MREvo
For Sale - Part Outs
34
Nov 18, 2014 01:05 PM
NOMIEZVR4
Oct 18, 2013 01:28 PM
MarylandEvo
31
Apr 16, 2013 12:06 PM
DubsE46
10
Dec 30, 2011 04:48 PM
