help with oil
Old Mar 19, 2018, 07:50 PM
sunnyhillkid's Avatar
help with oil
i just puchased an evo 8 took it for a ride started to smell a butning parked it in the garage and looked under to find oil dripping out and oil was on the hood of the car underneath and leaking down the front fender so obviously it was shooting out pressurized i really need help as to what this is
Old Mar 19, 2018, 08:02 PM
Pop the hood & w/ flashlight, look around carefully. Even w/the engine running. Make sure you have enough oil in the pan!
Or
Need to ramp the car up & get underneath to determine where the oil is coming from
Take a pic or 2 & post up
Old Mar 20, 2018, 08:34 AM
Dip stick probably came out.
Old Mar 20, 2018, 03:32 PM
thats what my mechanic said it was but im not sure i am not home right now ill check when i get back and let you guys know thanks for the help
Old Mar 20, 2018, 03:33 PM
2006EvoIXer's Avatar
How much power are you making to pop dip stick out?
Old Mar 20, 2018, 03:35 PM
400 whp 392 wtq
Old Mar 20, 2018, 03:48 PM
That's not much power to push dip stick out. Are you getting serious blowby? Do you have a catch can installed or mods to vent the head?
Old Mar 20, 2018, 03:59 PM
i have a catch can but its not vented
Old Mar 20, 2018, 05:48 PM
What turbo do you have and how many miles on engine?
Old Mar 20, 2018, 06:41 PM
an 04 with 120k miles but block was just resurfaced and timing belt, tensioner, water pump, head studs, and head gasket were all just done about 1300 mikes ago just tuned about 3 weeks ago and an FP Green dbb turbo
Old Mar 20, 2018, 06:46 PM
Is that 400 whp on a mustang dyno? You may want to look into venting your catch can with a big check valve to help release the crankcase pressure.
Old Mar 20, 2018, 06:48 PM
idk what a mustang dyno is
Old Mar 20, 2018, 06:51 PM
Most Mustangs read a bit lower than Dynojets (approx 15% IIRC). He was trying to gauge your WHP
Old Mar 20, 2018, 06:53 PM
oh im not sure then i think it is a dynojet i got it done at europlus
Old Mar 20, 2018, 06:55 PM
do you think an stm vented dipstick oil catch can would help possibly
Quick Reply: help with oil
