Help wanted!
Old Mar 22, 2018, 01:28 PM
EvoIIIAj's Avatar
Help wanted!
Hi guys,
Helping my friend out with an Evo X. Please see below:
Need a solution to an issue before i burn the car.....
1. Car was running fine. Tune was excellent
2. Car is starting fine when cold but goes to idling RICH 10 - 11afr.
3. Cruising is fine at 14 -15 afr but soon as lift of gas to slow down or stop goes back to rich .
4. Warm start doesnt work unless gas pedal is floored. If not plugs will be flooded and have to unplug injectors and crank n then plug bck in.
5. ALL sensors on engine have been replaced (coolant temp, map, maf, both cam sensors, crank sensor, iat, front o2)
6. CEL only shows system too rich error
7. If i try to go WOT afr goes lean.
8. Double pump hanger with 2 new aem pumps. 8an feed and 6an return. New fuelab FPR
Old Mar 22, 2018, 01:59 PM
ddawg1130's Avatar
What injectors?
And have any mods been made since the tune?
Old Mar 22, 2018, 02:04 PM
EvoIIIAj's Avatar
FIC 1650
No mods have been done since the last tune. The issue that randomly started happening.
Old Mar 22, 2018, 07:13 PM
Napalm_Enema's Avatar
have you changed out the fuel relays that are so prone to going to ****? Cheap thing to try first if it was good and now is not without any differences.
Old Mar 22, 2018, 07:15 PM
EvoIIIAj's Avatar
Just asked my friend if he changed those, he said already replaced.
Old Mar 22, 2018, 09:24 PM
Damn. How about this? http://www.evoxforums.com/forums/showthread.php?t=67324
Old Mar 23, 2018, 06:53 AM
EvoIIIAj's Avatar
That was also checked and done..
Old Mar 23, 2018, 01:43 PM
splattj's Avatar
What's the fuel pressure reading at idle when it's too rich? Could be a problem with the FPR or the vacuum line to it. The warm idle flood combine with lean under boost makes me think FPR
Old Mar 23, 2018, 01:51 PM
EvoIIIAj's Avatar
My friend’s reply:
Fpr at idle is 45psi. And i hooked up a long line and guage and rested on the windscreen and did a pull, it went up to about 70psi and was still lean.
To my knowledge he has also tried another FPR.
Old Mar 23, 2018, 03:01 PM
Swap injectors?
Old Apr 2, 2018, 09:50 PM
EvoIIIAj's Avatar
Originally Posted by Napalm_Enema
Swap injectors?
that’s about the only thing he hasn’t done yet. Will let everyone know when he does if those were the problem.
ksyu
Apr 1, 2004 08:57 PM
mikey
May 28, 2003 12:05 AM
Quick Reply: Help wanted!
