FS[SouthEast]: 2006 Mitsubishi Evolution IX GSR WW Excellent Condition
Hello guys,
-2006 Mitsubishi Evolution IX GSR
-102K miles (Clean title)
-18K miles on NEW (not rebuilt) 2.2L engine and Shep Ultimate Ratio Trans.
-GSR 5 Speed
-Wicked White
-Excellent Condition 9/10 interior and exterior.
-VIN: JA3AH86C66U054402
I’ve finally decided to sell the most enjoyable sports car I’ve ever owned. You’re looking at the most sought-after Evo with the best-of-the-best, tasteful modifications. I’m the 2nd owner. I purchased this car from a 45-year-old gentleman in Gilbert, AZ who took excellent care of it for the first 20k miles and I’ve meticulously maintained the car for the last 10 years. It runs great and has zero problems. The car is on a Haltech Platinum Pro ECU with Flex-Fuel setup. It’s 100% dialed in to run either 93 or e85. The current setup on 93 results in 470awhp and e85 = 580awhp. The engine is a custom spec 2.2L motor built by AG Autosports and is capable of handling 900+ hp. Just swap out the turbo and retune. All other supporting mods are already in place.
The calibration will be delivered “Un-Locked” so the new owner can easily make changes if ever needed. The car has been garage kept and professionally detailed its entire life. It has some rock chips on the exterior but not too noticeable. The only reason I’m selling is because I don't drive it much anymore and I’m picking up an Evora 400.
The new owner will receive a massive folder with all receipts, engine specs, warranties and proof of maintenance. I’ve attached a PDF copy of the clear title and just a sample of receipts.
Maintenance:
Oil changed every 4k miles with Amsoil Performance fluids.
Trans and diff fluids replaced every 10k miles.
Michelin Pilot Super Sports in excellent condition (less than 10k miles).
Engine:
AG Autosports Built 2.2L
New Mitsubishi 4G63 Block
Custom Spec Wiseco Pistons
Carrillo Pro H-Beam Connecting Rods 156mm
Manley 94mm Billet Crank
Balance Shaft Eliminator
Cylinder head port matched with Supertech Valves +1mm Inconel, Supertech Valve Seals, Ferrea Valve Guides, GSC Beehive Springs w/Titanium Retainers & Chromoly Seats.
GSC Power-Division Billet Evolution 9 Mivec S3 Camshafts
ARP L19 Head Studs
Forced Performance Xona Rotor 61-56 Ball Bearing Turbocharger
Sheepy Built Large Runner Manifold with Hood Exit Wastegate Pipe
Turbosmart Hyper Gate Valve
Turbosmart Race Port BOV
AMS Evolution VIII/IX Oil Cooler
STM Evo 8/9 Sealed Engine Oil Catch Can
Buschur Racing Short Route Piping
Buschur Racing Race FMIC
Buschur Racing Double Pumper
SparkTech CDI Pro 14-B Coil-on-Plug Ignition
AMS F-1i Intake Manifold
Boomba 75mm Throttle Body
FIC 2150cc Injectors
AMS Fuel Rail
Magna Fuel Pressure Regulator
STM 4” SD Intake
AEM 4 Bar MAP Sensor
Kiggly HLA
Koyorad Radiator
STM Stainless Steel Exhaust w/High Flow Mufflers
Braille Lightweight Race Battery
Drivetrain:
Shep Trans “Ultimate Ratio Trans” with Billet Output Shaft
Shep Trans Stage 2 Transfer Case
Quaife Differential
New Front & Rear Axles and Hubs
Lightweight 2-Piece Aluminum Driveshaft
Exedy Triple Disk (HD) Clutch
AMS Stainless Steel Upper & Lower Clutch Lines
WORKS Short Shift Kit
Buschur Racing Shifter Base Bushings
Buschur Racing Under Hood Shifter Bushings
Torque Solutions Motor & Trans Mounts
Suspension:
KW Coilover Kit V3 Mitsubishi Lancer CT0
Whiteline Front Swaybar
Whiteline Rear Swaybar
Whiteline Front Control Arm Bushing Kit
Whiteline Front Roll Centre Adjust Kit
Whiteline Rear Bump Steer Correction Kit
Buschur Racing Mustache Bar
Buschur Racing Side Diff Supports
AMS Lightweight Front Crossmember
Cusco Carbon Fiber Front & Rear Strut Brace
Enkei NT03+M Wheels
Brakes:
GiroDisc 2-Piece Slotted Rotors – Front
GiroDisc Slotted Rotors - Rear
Ferodo DS2500 Pads
Exterior:
JDM Bumper
STM Evo 8/9 Rear Bumper Support Bar
Shorty Antenna
APR Carbon Splitter
Toxic Fabrication Front Bumper Quick Release System
Interior:
NEW Recaro Sportster CS Seats
Planted Technology Seat Brackets
Sparco Steering Wheel with NRG Quick Release (Stock Steering Wheel Included)
Gruppe S Center Console Gauge Pod
AEM Digital Boost Gauge
AEM Digital Oil Pressure Gauge
AEM Digital Wideband Gauge
Kenwood KMM-BT312U Bluetooth Stereo
LLumar Ceramic Window Tint (Entire car, $850.00)
$33,000 OBO. Located in Sarasota, FL. No Trades. Will ship at buyer’s expense.
Call, txt or email 941-914-6614 or matthewlevonchristian@gmail.com
Video:
Receipts:https://drive.google.com/open?id=1uJ...cuoKKZC25LK-mQ
-GSR 5 Speed
-Wicked White
Maintenance:
Engine:
ARP L19 Head Studs
AMS Fuel Rail
STM 4” SD Intake
Kiggly HLA
Koyorad Radiator
Drivetrain:
Quaife Differential
Suspension:
Enkei NT03+M Wheels
Brakes:
Ferodo DS2500 Pads
Exterior:
JDM Bumper
Shorty Antenna
APR Carbon Splitter
Interior:
Video:
mchristian (Apr 5, 2018)
MinusPrevious (Apr 5, 2018)
