Should I buy this 1000hp evo?
Old Apr 23, 2018, 12:56 PM
Jonogiller's Avatar
This Car will NOT be my daily driver but I would still like to take it out every week or so and to the track every once in a while but my real question is how reliable do you think this car is? And if it will just blow up a month after I get it... here is the mod list
For Sale : 2003 MITSUBISHI EVOLUTION VIII
72K CHASSIS MILES
3K ENGINE MILES
CLEAN TITLE
SERIOUS INQUIRES ONLY
CONTACT ME : [hidden information] // Messenger
English Racing 2.2L Short Block:
ER Spec Wet Block
ER Spec Modified Oil Pump
ER Spec Carillo Rods
ER Spec Carillo 9:1 CR Pistons
ER Spec Eagle Crank
ACL Race Bearings
ARP Main studs
ARP 625+ Head studs
ARPCrank Bolt
ATI Race Damper
Gates Racing Timing Belt
Gates Accessory Belt
ER Spec Headgasket
English Racing Ported Head:
ER Machine Work
AEM Tru-Time Cam Gears
ARP Cam Gear Bolts
GSC +1mm Exhaust Valves superalloy & Intake Valves
GSC Valve Stem Seals
GSC Valve Guides
GSC Zero Tick Lifters
GSC Billet S3 Cam Shafts
GSC Beehive Titanium Springs & Retainers
Turbo Setup:
English Racing Forward Facing T4 Twin Scroll Manifold w/ 2" Hood Exit Dump Tubes
PTP Turbo Blanket
Precision Dual Bearing Twin Scroll 7175 Turbo
Tial Twin 38mm Wastegates
ER Pie Cut Side Exit Exhaust
Intercooler/Intake:
ER Spec Magnus V3 Intake Manifold
Boomba 75mm Throttle Body
ETS Custom 3" Titanium Upper/Lower Pipe
ETS Black Anodized 6" Race Intercooler
Tial 50mm MV-S BOV
Drivetrain:
Exedy Triple ( Brand New ) Less Than 50 Miles
ARP Flywheel Bolts
ShepTrans Stage 2
TRE Stage 2 Transfer Case w/ Wavetrac LSD
TRE 12Disc Maxlock Rear Diff
Driveshaft Shop 900hp Complete Front Axles
DSS 2-piece CF Rear Driveshaft
Cooling:
Koyo Black Anodized Half Size Radiator
Spal Radiator Fan
Fuel System:
English Racing Race Fuel System
-8 Feed & -6 Return Lines
Modified Buschur Double Pumper
Twin Walbro 450 E-85 Fuel Pumps
ER Spec Boost-A-Pump
FIC Black Anodized Fuel Rail
Injector Dynamics 2000's High Z Injector w/Resister Pack Delete
Engine Management:
AEM EMS V2 w/ Flex Fuel
AEM Back Pressure Monitoring & Cylinder EGT Monitoring
AEM Fail Safes Enabled
Sparktech Ignitions PRO CDI 14
Suspension/Brakes:
Supertech SS Front & Rear Brake LinesClutch Line
GiroDisc Front 2 piece Rotors
Stoptech Slotted Resr Rotors
ST43 Front Brake Pads
Project Mu Rear Pads
Motul 660 Brake Fluid
Tein CoilOvers
DC Sport Titanium Front & Rear strut Bar
Perrin Lower Control Bushings
MAGNUS Rear Subframe
Engine Bay:
STM Bracket Anodized Black
STM Overflow Bottle
STM Ppwer Steering Bottle
STM BFC Catch Can with Modified -12 Valve Cover Breather Lines
TCC Tirado Shaved Valve Cover
Zalkee Clear Cam Cover
Dressupbolts titanium Engine Bay bolt kit
ER Valve Cover & Cam Cover Heat Shield
DEI Heat Wrapped on all Boost Lines
Vibrant Boost Lines
ER ignition Mount
Torque Solutions Billet 4-Piece Motor Mount Set
Torque Solutions Billet Shifter Base Bushings
Torque Solutions Billet Shift Linkage Bushings
Energy Suspension Front and Rear Diff Bushings
Energy Suspension Front Lower Control Arm Bushings
Custom Wire tuck
Interior:
Full Evo IX Interior conversion(Carbon fiber Dash Trim,Carbon hand brake,carbon fiber arm rest)
Zeltronics Flex Fuel Display Custom Mounted inside Dash Tray
Sparco Harness Bar
4 point race driver & passenger seat belts
Exterior:
ER Font Bumper Quick release kit
Seibon carbon fiber hood
Seibon Carbon Fiber 10mm Wider Fenders
VIS Carbon Fiber Trunk
Aerocatch Hood Pins
JDM Amber Side Markers
JDM EVO IX Rear Bumper
JDM EVO VIII Headlights & Yellow fogs
LED Rear TailLights
Flat Lack Front lip
Angry Aero Front Bumper Shutters
Dyno:
Currently turned down making around 900whp on E85-E90
Price: $34,500
Old Apr 23, 2018, 01:03 PM
huzzle101's Avatar
Have you had a shop check it out for you, i don't think we can tell you from here how reliable it is. It sure does look good though and they didn't spare any money on the setup. Good luck.
Old Apr 23, 2018, 01:07 PM
Jonogiller's Avatar
yea I was going to have a shop look at It and get some compression numbers but other than that do you think this thing can even really be driven on the street or is it to aggressive? I have a 475 whp STI right now and it’s not that bad as a daily driver but ive never driven a 1000hp evo before so I’m not to sure what to expect
Old Apr 23, 2018, 01:08 PM
huzzle101's Avatar
Yea 1000 HP is a lot, i have heard of people driving those around, maybe not daily and you said you aren't looking to daily.
Old Apr 23, 2018, 02:36 PM
This car appears to have been built for the 1/2 mile. You will not be driving this on the street unless you get some work done. You should eliminate the open dumps & no way you will last on the street w/that side exhaust
It will take some work but im sure its doable
Not feeling the 34k price tag either (need more info/pics to justify)
Old Apr 23, 2018, 03:32 PM
e_kobz's Avatar
OP you realize who built this car right?! ER is in the top 3 best Evo builders in the country. I certainly wouldn’t have some basic performance shop “inspect” this car. ER built it, let them take care of it. Price is solid too
Old Apr 23, 2018, 03:56 PM
Saltyevo's Avatar
Personal opinion. 1k hp is wayyy too much. I personally feel like 600 hp if max for the street. Anything more is just for bragging rights. I don't think u would enjoy that as much as a 500 hp to 600 hp Evo. The only thing u could do on the track with that bad boy is drag. If that's your thing and want to invest a lot of money and time in it than go for it but I also think u would be much happier if u bought a shell and built it yourself then u could get is to it at different incriments rather that just jumping behind a 1k monster.
Old Apr 23, 2018, 04:00 PM
Saltyevo's Avatar
If u are seriously interested I would give Elglish a call and talk to them about the specific car in queastio. My Evo was built by them as well from a previous owner. I called them before I purchased it and they told me a lot about it and enticed me to buy it. I have had a great car with no problems ever since. Those guys at English are super nice and knowledgeable
Old Apr 23, 2018, 04:06 PM
Pal215's Avatar
There is not enough room on 99% of public roads out there for 1000hp, I promise. This car was built for drag racing, but has so many high quality parts on it, it's ridiculous. If you decide to buy that car, I would step down the turbo to the fastest spooling turbo that makes around 700hp and keep it that way. At least then the car will be somewhat usable on the street and parts will break much less than with 1000hp. Also, that exedy triple disk is built for track and drag. You CAN daily it, but the center hub will wear out faster than the friction disks. It doesn't like harmonic vibration. Still not a deal breaker if you can get the numbers low enough, ER 2.2's are the cream of the crop.
I wonder how on earth that thing was able to survive on public roads with Oceanside PD rolling around...
Old Apr 23, 2018, 04:21 PM
StreetLethal's Avatar
Correct me If im wrong but I believe that used to be English racings shop car or employee car. Not 100% needless to say its quite a beautiful car with parts to match!
BUY IT LOL! who cares honestly! Drive it like it is it would be a riot. I have a fender exhaust cops just give me a smile or thumbs up but that depends on the location and if you have to emission test or whatever.
Old Apr 23, 2018, 05:25 PM
hutch959's Avatar
Whenever someone ask "should i buy this 1000hp evo".... i say YES
HAHAHA
seriously...call english.
Old Apr 23, 2018, 10:01 PM
RazorLab's Avatar
There is no such thing as a reliable 1,000 hp Evo. Also if you need to ask a forum if you should buy a 1,000hp car, you probably shouldn't buy it.
Old Apr 23, 2018, 11:42 PM
Jonogiller's Avatar
I’m sorry if I don’t know as much about evos as you, I didn’t know this was a competition, I’m sorry for me being curious about what people have to say about this car before a make a decision or not, I really appreciate your input though
Old Apr 23, 2018, 11:45 PM
evobfy's Avatar
for 34/35k id personally pick up a closer to stock, or less modded out evo and focus on making good reliable power on the street
Old Apr 24, 2018, 04:21 AM
Jonno99's Avatar
plus get ER to pull it dow to 600hp then you can track it and go for some good canyon runs, even 600 is a tad to much
Quick Reply: Should I buy this 1000hp evo?
