Fuel Pump Getting No Power
Installed a walboro 450 pump with rewire kit and now the pump isnt getting any power from the car side. Checked all of the grounds I could remember. Anyone that has had similar issues any help would be appreciated.
The ecu only sends power when it detects engine cranking. So either you use evoscan to trigger the pump or test it while cranking. If you are still not getting power, double/triple check your install, check all OEM fuses with a DMM doing a continuity test (Beeps). Test all OEM relays.
Bottom right Select "Actuators" button. Then right under "Actuators" click the Activate button next to fuel pump.
BR350VIII004
13
May 25, 2016 07:22 AM
MisUnderStood
Dec 16, 2015 08:53 AM
Carloverx
14
Dec 22, 2011 01:00 PM
Octane Blue
Mar 28, 2011 09:07 AM
