Stock EVO 9 skips a beat/slight misfire
Old Sep 18, 2018, 04:03 PM
DilyanM's Avatar
Hello there, looking for some help with my Evo 9! I got the car last December, bone stock 2006 RS.. did all the necessary maintenance with only OEM parts, timining belt, puleys, tensioners, spark plugs, filters etc,running amsoil 10w30 signature. Car has NO mods, at least known to me..no exhaust no re-map..bone stock. It was running absolutely fine, until maybe begining of summer, when temperature started to raise. Car is running fine upon starting and until it warms up after that though it starts skipping a beat every 5-10seconds if i do a few hard runs and let it idle, the idle itself stays absolutely calm and steady, you can notice the skip at the exhaust, it changes its note for a second, whats weird is that it doesnt do it all the time..pulled out the spark plugs and looked fine to me / i DID NOT gap them btw, they have the stock factory gap/, dont think there is a vacum leak, its boosting all right, was sluggish during the hot days but that is normal. Now that the weather cooled down a little bit, it does not do it that often! I dont know what to check at this point..i was thinking maybe lifters or valvles? Car has 88,000 miles. I would appreciate any advice/opinion ! Thanks
Old Sep 18, 2018, 07:32 PM
llDemonll's Avatar
check the gap. .020"
Old Sep 18, 2018, 07:43 PM
DilyanM's Avatar
Yeah, i have not checked that, so will do. How come though it did not do it right after i put those spark plugs in?
Old Sep 19, 2018, 08:23 AM
llDemonll's Avatar
No idea, but it's one more thing that should be checked anyhow :shrug:
Old Sep 19, 2018, 08:30 AM
2006EvoIXer's Avatar
With my S2 cams, my idle sounds like it misses a beat every second too. Are you sure you have stock cams?
Old Sep 19, 2018, 08:38 AM
DilyanM's Avatar
Yeah i am pretty sure they are stock, car was running just fine when i got it,i should ve noticed if the cams werent stock. Coincidence or not it started doing it with the beginning of summer. I will gap the spark plugs, gap could have gotten even bigger ever since put them, 5k miles on them now,.
Old Sep 20, 2018, 01:01 AM
Wicked_X's Avatar
Man this is funny. I was having the exact same problem with my car for the first month or so I had it. Drove me crazy. It felt like it would skip a beat all the time! I can tell you one thing, that once I quit putting crappy CA 91 gas in it and strictly run e85, it idles great. My tuner is running like 10 degrees of timing at idle which may be what fixed it.
Old Sep 20, 2018, 07:27 PM
Wanted EVO IX's Avatar
My car has a slight miss at idle sometimes. I figured it was the MAF but have cleaned it many times and the miss always comes back. I want to do new spark plugs again and gap them as well. My car will miss most if I run it hard while hot temps outside. When I get off the gas to let it idle it will have a miss, pulling a away from a stop it will miss slightly for a moment then be normal. Driving under acceleration it pulls like it should no issues. I have never figured this out.
Old Sep 21, 2018, 10:34 AM
slocho's Avatar
I had the same issue when my car was on stock cams, it would sound like a misfire but engine would never stumble and idle wouldnt drop so i never worried about it. Plus it drove just fine so i figured it was "normal". If anything you could replace the spark plug cables with new OE ones.
Old Sep 22, 2018, 05:23 PM
boostedwrx's Avatar
Check grounds, add grounds, laugh if you want but I added a few grounds and my mfer idles like a champ now. Well as much as it can with S3’s
Old Sep 22, 2018, 05:45 PM
Biggiesacks's Avatar
follow all the hoses around the throttle body and make sure nothing popped off. Then do a boost leak test.
Old Sep 24, 2018, 07:32 AM
Redline-Z's Avatar
This, check your negative terminal and clean up grounds.
Old Sep 25, 2018, 03:08 PM
DilyanM's Avatar
Believe it or not a had a bad/disconnected negative, the one right behind the intake and under the strut tower bar! Replaced it last night with a aftermarket one, a bit larger...so i cross my fingers and see how that goes! Cleaned the +/- of the battery as well ! Thanks for the responses,will keep you posted.
Old Sep 25, 2018, 03:09 PM
DilyanM's Avatar
Old Sep 25, 2018, 08:56 PM
TomekEVO's Avatar
Mine does the same. Its like a hiccup at idle when I start the car up and let it warm up. Car runs fine so i just assumed it normal
