New guy here Looking for 400Whp is my list good?
- Hey guys I知 new here I知 sorry if I did not post this in the right thread. I have a 2006 Evo RS five speed the car is bone stock right now. But I had just got my signing bonus from the army it is $15,000 I知 wanting to spend half of it so 7500. Here are a list Of mods I had picked out currently I知 looking for 400 WHP-450 WHP on 93oct here is the mod list
- Ultimate racing CAI $85
- Grimmspeed EBCS $115
- ETS FMIC $600
- Ultimate Racing Catted DP $350
- N1 CBE $450
- GSC Power Division S2 Billet cams $600
- GSC Power division Beehive Valve Springs/Retainers $350
- Apr Headstuds 130$
- Shep 8mm to 10mm bolt stage 1 transfer case $1,100
- Stage 3 Competition clutch rated for 525WTQ $550
- Fuel Injector Clinic 2150cc Injectors $750
- Deatschwerkd DW300 Fuel Pump $150
- FP Red Turbo $1100
- ATP Adjustable FPR $170
So my total is 6500 so I have some room for labor for the cams and other stuff
the injectors are huge for your goals and probably too big for that pump. You should probably add a wideband + evoscan + Openport 2.0 to your list. You should also probably add at least a LICP if you are going to upgrade the IC. If your going to use the stock exhaust manifold you should have that ported. Then add the cost of all the misc. stock **** your gonna want to change when doing all this, gaskets, hoses etc. This is all assuming the car is up to date on all its maintenance and doesn't have any other issues that need to be sorted.
Great news. You are already an owner
Welcome Aboard for sure
Great to see you are already investing w/some mods. If you like you can post up here & keep us all posted on your progress
Post up here if you like: https://www.evolutionm.net/forums/pr...d-threads-344/
We love pics!
Again, welcome, Joe
We love pics!
Again, welcome, Joe
ok I see appreciate the comment I’ll look into all those could I look into a Walbro 450 fuel pump? And the car is very healthy right now just under 93,000 miles as well. And yea I forgot about the misc lol. Definitely get a better Head gasket as well. I’m actually gonna do my timing belt next week as well as my valve cover gasket so she’ll be nice and ready.
Yah I think a 450 would be a step in the right direction, but still probably more then you need for your goals. You will also want to pick up a wiring upgrade kit for the fuel pump. If you are going to pull the head then the opportune time to do that would be when you do the timing belt job. While the head is off you could consider having the springs professionally installed so they can check installed height, seat pressure etc.. Same with the studs, you will want to do those when you do the new gasket. Make sure you do the balance shaft belt too while your at it and a new water pump is also a good idea when doing the timing belt. Stuff adds up quick with these cars
If the goal is on 93 octane i'd get the the DW300 or Walbro 255 and just get 1000cc injectors or something as they are plenty for your goals on pump gas.
Also the FPR isn't needed the factory one will do a right old job with a DW300 or a walbro 255.
I made 410whp on a FP green and HKS 280's on factory fuel wiring on a Walbro 255 on 98 Ron. ( similar to 93 in the states. )
I had a feeling you where trying to future proof your fuel system. Just know there are trade offs in the cars manners when it comes to over sized fuel systems. Make sure you bring your tuner a hot meal
Just my opinion, of course (per my sig LOL). I haven't read the rest of the replies yet (on the mobile app):
400whp is a SERIOUSLY cheap goal.
- Ultimate racing CAI $85 - Not needed. Just need an open-element air filter
- Grimmspeed EBCS $115 - These work great.
- ETS FMIC $600 - Which size? you don't need too large at this power range. Too big = less turbo response with no upside.
- Ultimate Racing Catted DP $350 Probably won't make 400whp through a cat.
- N1 CBE $450
- GSC Power Division S2 Billet cams $600 - Great cam.
- GSC Power division Beehive Valve Springs/Retainers $350 - Good idea, with those cams.
- Apr Headstuds 130$ - Not needed. Stock head bolts are just fine.
- Shep 8mm to 10mm bolt stage 1 transfer case $1,100. - Not needed.
- Stage 3 Competition clutch rated for 525WTQ $550 - I'm not sure what a "stage" is, but the ACT HDSS is probably the best all-around clutch there is and will hold more torque than you will be making.
- Fuel Injector Clinic 2150cc Injectors $750 - Way too much injector. Only need 750cc for pump gas or 1050s for e85.
- Deatschwerkd DW300 Fuel Pump $150 - Not needed. Just need a Walbro 255 dropped in.
- FP Red Turbo $1100. A stock IX turbo can do 400whp on e85. If using 91oct, then a Red would do 400whp easy. If on 93oct, then maybe an FP Green...? Not sure, though.
- ATP Adjustable FPR $170. Not needed.
