Evo X MR 450hp/356ft-lb Stock Block
Old Oct 7, 2018, 05:47 PM
Jaraxle's Avatar
My build thread is linked in my signature below.
I am calling this my final results, because I don't dare go any further on the stock block with factory SST. The spool is ACTUALLY as fast as stock, that's the crazy part.
I bought the car new in 2012 by trading in my Z06. I bought an MR to deal with city stop/go and kids in the back seat, and as a MENTAL block to prevent me from going too crazy on mods. At the time the SST was thought to not be able to handle power. Well you can see that MENTAL block was overcome.
E85 (sensor reading E80)
FIC 1200's
Walbro 255 @9volts pumps fuel to a custom 2 liter surge tank
DW350il pulls from the surge tank and pumps to the OEM fuel rail
Custom built solid state pump voltage controller controlled by factory ECU (just like stock!)
MAP cast stainless exhaust manifold
AMS cast stainless downpipe
SS Testpipe, Vibrant resonator, Magnaflow CB
CP-E intercooler (often ignored; this guy is massive and made in the USA)
Cobb Accessport <-----
20G 7+7 compressor with 9 blade STS TD05H turbine (MHI center section), TurboSmart actuator
Self tuned.
The rest of the parts & mods are less important for power.
Red line is a 3rd gear pull and Blue was a 4th gear pull. They were done back to back, and obviously the higher gear causes more torque and quicker spool. Stock was 220hp.
turbo addict (May 23, 2020)
Old Oct 20, 2018, 09:00 PM
Jaraxle's Avatar
20 psi at 3000rpm and 450hp to the wheels @7254 rpm and over 300 views with zero comments !?
Old Oct 22, 2018, 03:26 PM
A lot of those view are probably bots. This website resets it's visitor record almost daily even though it's pretty much dead...
Good results though. Stock trans should remain fairly happy there.
Old Nov 1, 2018, 02:12 AM
Awd_evo's Avatar
Impressive power band !!! By the way any cooling upgrades done on the transmission?
Old Nov 1, 2018, 10:09 AM
Jaraxle's Avatar
Yes sir!
https://www.evolutionm.net/forums/mi...ler-build.html
Old Nov 11, 2018, 09:10 AM
IzzyRS's Avatar
Very nice usable power! Any reasons why you chose to go with a surge tank on this build? Seems a bit overkill for daily driver duties lol.
Old Nov 11, 2018, 01:21 PM
Jaraxle's Avatar
I'm sure you know the stock tank is a ticking time bomb for thirsty (e85) cars.
Surge tank is for track duties. I used to do HPDE a lot when I lived near Watkins Glenn. Now I am closer to Palmer and am looking at getting back into it.
Also, it's nice to run the tank SUPER LOW for 1/4 drag racing which I do now and then...
IzzyRS (Nov 12, 2018)
Old Nov 17, 2018, 11:47 PM
Any EvoX running E85 on a road course needs a surge tank..
Old Nov 18, 2018, 09:50 AM
RazorLab's Avatar
And an upgraded fuel basket if frequenting a track that has higher G left turns.
Old Nov 27, 2018, 02:40 PM
LanceKA-T's Avatar
Fantastic powerband, well done.
Old Dec 8, 2018, 04:52 AM
turbo addict's Avatar
Still stock clutches? Nice set up!
Old Dec 8, 2018, 07:04 PM
Jaraxle's Avatar
Yes, and Thanks!
I keep up with maintenance of the fluid, and use an external mounted massive & high flowing 15 micron filter (covered in my build thread).
Also notice I am limiting my peak torque to keep the clutch pack happy.
Old Feb 11, 2019, 10:38 PM
SnailSpeed's Avatar
I built a similar turbo for my brothers evo 8 a while back. Very potent combo, on 92 octane and 27psi peak it put down 375whp in virtual dyno in dynojet mode.
