Power levels so far/shed built.
Old Oct 12, 2018, 08:32 AM
Evo8cy's Avatar
2.0L forged.(blueprinted). Self built.
Custom fuel system-self made.
1260cc injectors.
Adj FPR.
Upgraded fuel rail.
MAP ported stock inlet mani, (ported some more and re-cut and welded by me).
Boomba 75mm t/b.
Ported head /blended chambers /lightly polished by me. Bigger valves/new guides/ resurfaced to my spec by a local machine shop. Upgraded springs with Ti retainers and seats.
Custom turbo (6868).
Custom downpipe( fabricated by me helped by a friend).
Custom exhaust system-self fabrication.
Log type manifold, ported and modified by me.
Custom external setup with hood screamer, again self fabrication.
Self made COP.
Self made intake pipe.
R34 gtr 4,5"- 3"inlet/exit /tube and fin type /max fin/cm ratio/
excellent heat disperse/exchange capacity.
Custom made intercooler piping-self made.
Larger oil cooler setup.
Custom work on gearbox-self made ( 6 speed).
(The work on the box was done in 2005)
Custom mapping also done by me.
Recent power figures :
Marios
Evo8cy is offline
Old Oct 12, 2018, 08:42 AM
Way to go Marios
Amazing power! Hey, how about a pic of your car & the engine?
Dont think Ive ever seen your car
Joe
MinusPrevious is offline
Old Oct 12, 2018, 08:47 AM
Evo8cy's Avatar
Yeah its not bad Joe, I'm sure over there you've got much stronger cars.
I'll post a couple of pics later on, although it ain't much lol. Cheers Joe.
Marios
Evo8cy is offline
Old Oct 12, 2018, 08:53 AM
Project_Broke's Avatar
Do you have 8 injectors? Not sure how that power level is attainable with 1260's.
Project_Broke is offline
Old Oct 12, 2018, 08:59 AM
Evo8cy's Avatar
No I have 4 injectors, 99% duty, 55psi base fuel pressure / race gas.
Marios
Evo8cy is offline
Old Oct 12, 2018, 10:14 AM
Evo8cy's Avatar
Here you go Joe,
Evo8cy is offline
Old Oct 12, 2018, 11:04 AM
Originally Posted by Evo8cy
Here you go Joe,
Thanks Marios, Looks cool. Its a "Sleeper"
Old Oct 12, 2018, 11:17 AM
Evo8cy's Avatar
Thank you my friend, appreciate the nice comments, I've also painted the car and parts myself.
Marios
Evo8cy is offline
Old Oct 12, 2018, 01:25 PM
2006EvoIXer's Avatar
Big power!!!
2006EvoIXer is offline
Old Oct 12, 2018, 02:03 PM
Evo8cy's Avatar
I just wanted to clarify that the fuel used here is a new pump station 100oct race gas fuel ( aprox.102 ron), it is a racing formula blend by a local fuel brand. This blend has a much higher calorific value and % density than ethanol and by my testing it can take at least the same amount of timing as pump e-85 at the same boost. The advantage with e-85 is that it includes in its bio-molecular chain the oxygen molecule which allows for much more fuel to be added and thus density overcomes the lower calorific value.
Marios
Evo8cy is offline
Old Oct 12, 2018, 02:32 PM
Evo8cy's Avatar
Originally Posted by 2006EvoIXer
Big power!!!
Cheers mate
Marios
Evo8cy is offline
Old Oct 12, 2018, 02:47 PM
Pal215's Avatar
There is something very different about this build. Nice work OP! Congrats and have fun with the new found power.
Pal215 is offline
Old Oct 12, 2018, 02:56 PM
Evo8cy's Avatar
Thanks my friend, enjoy your evo as well!
Marios
Evo8cy is offline
Old Oct 13, 2018, 01:42 AM
ConEvo's Avatar
Amazing power. Enjoy. Nice build with nice results and definitely a sleeper. About the 100ron, it seems that it is working very well
ConEvo is offline
Old Oct 13, 2018, 01:58 AM
Evo8cy's Avatar
Thanks mate, well it seems that it does, it also seems it is a bit more than 100 ron, around 102ron, as there was an older version of this 100 oct by the same fuel brand, but it was not signified as a racing formula blend, this one is and it is as such in pragmatic application also as it can take 4-5 degrees more timing at the same boost than the older version of it. Also dyno results are higher than before showing that it has higher density and calorific value.
Marios
Evo8cy is offline
