FS: Evo 8/9 parts
For SaleEngine - Power Adders
Price
$123,456• OBO
- Location Buffalo, NY, 14223, USA
- Condition Used
All of these parts came off my 03 Evo 8.
Evo 9 turbo. Comes with oil/water lines, wga/manifold . Has about 54k miles on it with no in/out shaft play. It has the slight side to side that all jb turbos have. Does not smoke and boosts great. $500
Stock evo 8 intake manifold and tb. No issues besides being dirty. $150
Stock fuel rail $50
Cobb XLE BPV Needs a new o-ring kit $150
RC 1000cc injectors. Worked fine was always ran on pump 93. $150
3" intake pipe and filter. Has a - 10 fitting welded on. $50
Evo 8 enkeis with hankook snows. Plenty of life left. Has some blemishes and could use a full refinishing if you wanted a nice set of wheels. Work great for winter wheels though. $400
Evo 8.5 turbo had 100k miles. Might be good for parts or just the 10.5t hotside. The hotside has the usual cracks but not bad from some I've seen. $150
Evo 8 valve cover. Tapped for - 10 fittings but really needs to be cleaned with the baffles removed. Bought to install but got a coated one ready to go and never installed. $250
Qtp O2 dump. Has dings and a stripped dp bolt hole. No cracks though. $125
Hallman MBC $50
Omnibar 4bar $75
