Flash Evo 7 GTA ROM into Airtrek Turbo ECU
Old Dec 13, 2018, 01:16 AM
rjwkerkhof's Avatar
I have read that people are flashing a E7 GTA Rom into an Airtrek Turbo ECU and thinking of doing the same as the 3 port boost control must be better (without boost / fuel cuts when shifting) compared to the normal Airtrek ROM. Are there any important things when flashing the E7 GTA ROM to Airtrek ECU to keep in account?
Thanks in advance,
Roy
Old Dec 24, 2018, 03:16 PM
sikest's Avatar
Re-scale maf values or upgrade to Evo 7 to 9, re-scale injector scaling. Will require the xml to be edited for the read method.
rjwkerkhof (Dec 25, 2018)
Old Dec 27, 2018, 12:06 AM
OzAirtrek's Avatar
Yes and actually this has already been done by the airtrek--turbo.ru guys.. They have them for download modified for airtrek MAF, injectors and also gearbox (which has different shift settings).
GTA rom seems better option for 3 port as definition has the BCS correction latency defined.. I think there is also a table for ingnition retard on trans shift...
I had issues getting 3 port to work well with 010 rom .. it did work but would over boost on gear change.
Interested to hear if you get it to work well with the GTA rom
Old Dec 27, 2018, 12:33 AM
pisyakot's Avatar
Because 807 don`t have wgdc map on gear change
Old Dec 27, 2018, 12:51 AM
OzAirtrek's Avatar
Yeah it must be in there but it isn't defined..
Old Dec 27, 2018, 02:28 AM
pisyakot's Avatar
No man, i disassembled this rom. 89970010, 80700017 and 88780004 have these maps
Old Dec 28, 2018, 09:07 PM
OzAirtrek's Avatar
Do you have a better definition? Can you post the table for 89970010? Thanks!
Old Dec 28, 2018, 09:32 PM
sikest's Avatar
I obtained an updated XML from Merlin but it is not free. 2byte load, logging boost with evo x 3 bar, using a bcs to control boost , with various other features. I am also interested in certain feature from Pisyakot. I am hoping he has resolve SD for the auto airtrek.
Old Jan 5, 2019, 10:01 AM
pisyakot's Avatar
No man, i haven`t. if you need any specific tables, I can see
Yup, i made this. But i don`t like old implementation SD (maf translator). Here is one of the cars on SD mod
Today i use true sd implementation based on lancer rom (4g18 no maf rom). It`s my 2.4l with mivec head on map
Old Jun 16, 2021, 03:38 AM
Rovin Raj's Avatar
Hi. I can see that you modified the 4g18 ECU and the rom. i have the ecu, but from and XML is not properly defined. Would you share me the the ROM with XML? i do not mind paying you pennies, I would be happy to pay you to help me
