Evo 8 possible power levels
Hi
One of my friend's just got his Evo 8 tuned with the following mods:
- Cat-back Exhaust
- Intake
- Braincrower Stage 2 Cams
- Water/Methanol Injection
If the torque is in NM its really low, if it is in LBFT its great. Peak torque is really late for this setup especially running water-meth injection, and AFRs could be a little richer at spool
and leaner in the high rpms for best results.
Mailine dynos are typically heartbreaker dynos so peak HP numbers are good.
the mainline dyno has a weird way of reading, i think there usually is a conversion you have to do to get numbers from. my civic when i had a built k24 made "239" according to the mainline but my tuners conversion estimated 273, i dynoed on a mustang md150 a few weeks later and the car was making 271whp. so basically they spit out a number that is around 12% off so i estimate your bud's number to be around 320-330whp
What sort of power levels would you typically see with this mods?
