Evo 8 9 turbo Forced Performance HTA-71 Turbo 10.5 MHI housing complete
For SaleEngine - Power Adders
Price
$1,799• OBO
- Location Lakeland, FL, 33812, USA
- Condition Used
- Compatibility
Make | Model | Year |
Mitsubishi | Lancer Evolution | 2003 - 2006 |
Like new Evo 8 9 Forced Performance HTA 71 turbocharger with anti-surge ported cover, O2 dump, turbo exhaust manifold, heat shield, coolant lines, oil return line, turbo blanket, evo 9 28psi wastegate and items listed below.
Amazing spool and tons of power!
All parts came off my 2003 Evo 8 after 100 miles. Literally like new. I went a completely different route with a fully built new 2.0LR complete drag race motor, 2150cc injectors and dual ball-bearing Precision Turbo 6466.
Pictures speak for themselves. All powder coating is intact because it has less than 5 heat cycles before the whole set up was taken off the car. Over 400 positive feedback on my profile.
What you see in the pictures is what you get.
Forced Performance HTA-71 turbo compressor $1075 with OEM Genuine Mitsubishi MHI TD06HR 10.5cm ported and powder coated exhaust turbine housing $360
EVO IX 71HTA Super Core
oCompressor wheel - 71HTA
oFlow rating - 51LB per minute
oCW Measurements - 51.2MM Inducer / 68MM Exducer
oTW Measurements - 55.9MM Inducer / 49MM Exducer
oCompressor Housing - 84MM Flow Advancement Port Cover
oCHRA - FP Journal Bearing
The FP 71HTA Super Core is the best "Plus One" upgrade for your Evo 8/9 project.
Forced Performance Evo HTA-71 install kit $149
oOEM Evo 8/9 Compressor Outlet Pipe
oEvo 8/9 Water Lines
Evo 8/9 oil drain tube
oOil Drain tube gasket
oTurbine Housing Inlet gasket - Open or Divided
oTurbine Housing Outlet gasket
oCompressor Housing to Outlet Pipe gasket
Turbo blanket $75
Curt Brown ported and powder coated turbo manifold $150 for porting $150 for powder coating (not including cost of actual OEM manifold)
Powder coated turbo manifold heat shield $70 (not including cost of actual OEM heatshield)
Powder coated and ported JM fabrications O2 dump $386.74
FP Evo 8/9 3.25" / 84mm Intake Pipe $129.00
K&N Filter with adapter to FP intake pipe $135
Forced Performance EVO 9 wastegate 28PSI $100
Partially heat wrapped O2 dump tube.
$2779.74 plus shipping costs in receipts, not including labor.
Any questions please feel free to contact me, Thank you for looking at my listing and happy bidding.
Keywords: HTA-71
Sold AS-IS.
Turbo blanket $75
Keywords: HTA-71
Sold AS-IS.
