Wisco pistons rings question
hello ,
im rebuilding my evo 8 engine which will be running on E85 and will be using links ecm to get it tuned.
Going to use Wisco pistons and Manley rods my aim is to go for 600 to 650 Hp.
using 6266 Gen 2 turbo
just wanted to to know what will be the correct ring gaps for Wisco pistons with standard bore using e85
thanks
thanks
For Wiseco rings, .018" top and .024" on the 2nd will be fine. Then of course make sure the oil rails have >.010"
On E85 the gen2 6266 should get over 700whp, I'd run a .0045-.005" ptw clearance to make sure you don't black death a piston. That PTW will work well to over 900ish as well if you end with a larger turbo at some point. And hopefully you got the Wiseco HD's, not the standard pistons. If you really plan to keep it around 600-650, .004"-.0045 will be fine on the ptw.
The following 2 users liked this post by LetsGetThisDone:
2006EvoIXer (Jan 18, 2019),
Pal215 (Jan 24, 2019)
so far I’m planing to keep it around the 700 for now
and yes I’m getting hd Wiscos
