JE 10.0:1 85.5mm piston set for 2.3L stroker
For SaleEngine - Internals
Price
$275• OBO
- Location Inverness, FL, 34453, USA
- Condition Used
- Compatibility
Make | Model | Year |
Mitsubishi | Lancer Evolution | 2003 - 2006 |
Just as the cams that came out of the car, the pistons were also replaced with lower compression units. Included are the pistons, wrist pins, and wrist pin locks-- no rings. They are ~10.0:1 compression ratio based on JE's website and are for a 4G63 block with a 100mm stroker crank. The bore is also for a +.020" (.5mm) oversize. All in all no issues and simply a casualty of changing the setup of the car.
The part number should be JE# 361291
