Is this the correct crankshaft for a 2.3l build?
I'm pretty confident that this is the correct crankshaft but I would like a peace of mind when others also confirm, and can I use those bearings and thrust washers as well
https://www.ebay.com/itm/331175242251
It's not about price vs lasting here. If you balance the 100mm OEM crank with your piston and rod assembly and run a fluidamper, it should last a long time. The bearings are correct and the crank SIZE is correct, but we don't know if that's an actual OEM FORGED Mitsubishi crankshaft. The ACL bearing sets for the 4g63 and 4g64 are the same down to the thrust washers. The ad says "Brand New OE Replacement Forged Crankshaft" at the bottom, but this picture shows CASTING lines. Can the seller clarify if that is a Mitsubishi OEM Forged crank?
On Ebay, Yes. I just bought a used OEM 4G64 crank for an extra 2.4LR build for $100.00 shipped and in great condition. It's not unheard of to see these things go new for $270.00 on sites like that. As a result, I would still assert that price does not always have to do with quality. You'll miss out on a lot of good deals with that mindset especially if you know what to look for.
