How do i get my evo to trap 145 150
Old Mar 24, 2019, 11:22 AM
Dakota Evo's Avatar
Currently have an ets 6262 kit
dual pumpers
id2000
stock ecu
s2 cams
2.3 stroker kit
Jdm rs weigh arouns 2950 lbs
26" tall motorcycle slicks
should I change to a 6266 gen 2 or 6466
head is on oem apring dont want to rev over 8000 rpm eitherway on 2.3
Old Mar 24, 2019, 11:52 AM
whtrice's Avatar
What does your car currently ET and trap now? What do you tach now through the lights?
Old Mar 24, 2019, 11:58 AM
Dakota Evo's Avatar
last time i tracked it was with an og green went 11.2 at 123 mph on e30 ethanol
Old Mar 24, 2019, 12:07 PM
ctfpevoVIII's Avatar
The 26” tires should help and you can lower your gearing , maybe 4.11.
Old Mar 24, 2019, 12:18 PM
Dakota Evo's Avatar
I like 4.3 gearing incase I go back to stock frame
Old Mar 24, 2019, 12:28 PM
that will work, but don’t know with that gearing and 26” tire if you get the traps you mentioned, I’m sure some one will chime in. I also have a 2.3 and don’t want to exceed 8,000 rpm.
Old Mar 25, 2019, 09:40 AM
whtrice's Avatar
To achieve 145mph with 26 " tires and 4.30 gears in 4th (1:1) you are @ 8057 rpm. If you don't want to over rev then your shifting to 5th.
https://speedmaster79.com/tools/rpm/
Old Mar 25, 2019, 01:35 PM
badev0's Avatar
The 6466 will definitely get you to 150mph. My best trap with a 6262 was 146mph @ 42psi with a 2950lb race weight.
Old Mar 25, 2019, 04:48 PM
Dakota Evo's Avatar
How many whp?
Old Mar 26, 2019, 06:35 AM
badev0's Avatar
How many whp?
It made 630 on a mustang dyno. Torque was just under 500.
