End Links to Stop Clunking
I recently swapped in whiteline front and rear endlinks on the evo to stop some suspension clunking - primarily the front, but I decided to add the endlinks to the rear while I was at it. Now both front and rears are clunking - is there a tricky to setting these up to stop the clunks? Only happens in hard cornering, ie autox & track
I actually had to re tighten the front endlink(like a quarter of a turn) the other day, it cleared up a lot of the clunking.Still have very little clunking left, but that's because one of the endlink brackets(same aftermarket fsb bracket you have)is kinda hard to tighten since the clearance and I got lazy. Also another side note, I don't know if you took off and put back on the axle nut but my axle nut I didn't put the cotter pin back in and the nut had to be tightened an extra good quarter of a turn more and that also eliminated some clunking. But I guess the obvious which I'm sure you're aware of, check, pull/yank arms, tire/wheel or whatever to make sure nothing else has play.
I happen to have a set waiting to go on the car. It's a 5mm, or at least thats the metric size that fits. It might be standard. While the instructions don't say it, the nuts kind of feel like the one time use types. So if they keep coming loose you might try replacing them.
Right.
Noise -> new end links -> even more noise = not the end links?
Maybe a part is making noise and wore out the old end links. Now that you have new end links, the noise is louder, for example.
Doesn't seem right the noise would get worse with new parts.. then to blame those parts.
Not sure I'm explaining what I mean, very well.
so for example, the rear sway bar & endlinks were updated. The only change in the rear is the RSB & the endlinks. They didn't clunk, now they do. The old (aftermarket still) RSB and OEM endlinks didn't clunk.
So the only source of rear clunking is RSB itself or endlinks. I'll re-tighten the RSB mounts, otherwise it is the endlinks.
