Ford Mustang gets the Ford Focus RS engine!
Old Apr 15, 2019, 12:59 PM
moparfan's Avatar
Minus 20hp, that is. I don't understand Ford.
https://www.caranddriver.com/news/a2...mance-package/
Old Apr 15, 2019, 05:31 PM
WarmMilk's Avatar
I was under the impressions that its always been the same engine...
Old Apr 15, 2019, 07:19 PM
kaj
kaj's Avatar
Put in the less desirable engine. WTF? I guess Mustang owners will also be swapping in ST engines.
Old Apr 16, 2019, 06:08 AM
whtrice's Avatar
Not much to understand with this company anymore, they only have a few car models to deal with... My guess is they have allot of blocks and tooling in Germany leftover so they need to cram it into the Mustangs...... oh wait.....Maybe a RS Ranger too......
https://www.roadandtrack.com/car-sho...ranger-engine/
Old Apr 16, 2019, 09:04 AM
Biggiesacks's Avatar
warped heads for all
Old Apr 16, 2019, 09:38 AM
RS200's Avatar
I like the EB 2.3, I'll be swapping one into my 1965 Mustang if/when I get done with my Evo.
This is silly, though. Basically the HPP Mustang has bit more power throughout the RPM band (but still not Focus RS-level for some silly reason), this is not exactly game-changing. The major performance difference between the Mustang 2.3 and Focus RS 2.3 was in the turbocharger, but the existing 2.3 EB in the Mustang responds very well to bolt-ons and tuning, so this is essentially moot. They need to fix the ridiculously bad exhaust sounds that it makes first.
Old Apr 16, 2019, 10:47 AM
Different cylinder head.
See above, due to the different head, it takes a different gasket. All the head gasket issues were due to the wrong gasket being installed at the factory. Ford has rectified this. It is not a less desirable engine.
Old Apr 16, 2019, 10:49 AM
See above, due to the different head, it takes a different gasket. All the head gasket issues were due to the wrong gasket being installing. It is not a less desirable engine.
Oh really, thats what it was, just a massive assembly line **** up?
Old Apr 16, 2019, 10:50 AM
Yeah, pretty much.
Old Apr 16, 2019, 03:48 PM
kaj
kaj's Avatar
I just know a friend of mine has been through three head gaskets and RS guys have been swapping in ST engines, according to him.
Old Apr 16, 2019, 04:17 PM
lv05evo's Avatar
The RS head gaskets were done by dealers free of charge of course. Problem is I think some dealers were not well versed on the RS engine and all the timing and what not that needed to be set just right. Big pain in the *** as dealers always think they are never wrong.
ST engine swap was for the guys that wanted to run more power. I thought the ST block is iron(I don't remember for sure) where as the RS is aluminum open deck design.
Stupid a$$ cars if you ask me. "Fake" all wheels drive system that will can and will overheat on the track and reverts to FWD until the temps lower.
Old Apr 16, 2019, 04:52 PM
kaj
kaj's Avatar
Interesting: after the last head gasket fix, he's down about 40whp. I wonder if they reduced timing to band aid the gasket.
Old Apr 16, 2019, 05:31 PM
That literally makes zero sense. Ford figured out the issue, and its not the tune. It was the wrong HG installed from factory.
I spent 10 minutes googling this and found nothing. Sleeves are already available for the RS block. The ST engine is aluminum also, so I don't see the agin from a different block. Maybe a few people did this due to unfound fear of the headgasket problem, which, for the 937th time, has been resolved. Idk why your friend keeps popping them unless the dealer isn't doing the job right.
Old Apr 16, 2019, 05:38 PM
deylag's Avatar
IIRC, 2.0L ST engine is a closed deck design.
Old Apr 16, 2019, 06:25 PM
kaj
kaj's Avatar
The first part was my being facetious, that's why I left a smiley face. His car is down on power since the last time it was serviced. Ford says they won't do anything without a fault code.
The ST engines are what he told me he's seeing on the forum, don't shoot the messenger. I won't even pretend to know why his car has been "fixed" three times. He did say Ford found the problem with the head gasket. Not sure if that was the last fix or not.
