Negative terminal clamp cracked
Old Apr 23, 2019, 08:41 AM
Boostevoviii's Avatar
Hey guys , have an evo 8 and I have a slightly problem with my negative terminal clamp, as you can see it’s cracked . I’ve been searching and all I see is that you have to run a longer harness wire or something like that to get it fix . Can someone please help a solution to this .
Old Apr 25, 2019, 03:47 PM
deylag's Avatar
Just need to order this harness to replace the old one.
https://stmtuned.com/products/positi...ap-oem-evo-8-9
Old Apr 25, 2019, 04:43 PM
Biggiesacks's Avatar
If you don't want to spring for the harness, you can just cut it off and install an aftermarket replacement.
Something like this would probably be the easiest to set up.
https://www.mcmaster.com/7980k52
I'm pretty sure that's the right gauge but you might want to double check.
Old Apr 26, 2019, 06:17 PM
Fox_IX's Avatar
Definitely the best option, but the ground cable will likely be too short once you cut it so you'll probably have to extend it or just build a new one.
