What RequestID & ScalingFactor for AFR Logging?
If you are logging AFR in evoscan, what values are you using for the "RequestID" and "ScalingFactor" in your evoscan data.xml? Im using a AEM UEGO if that matters.
In this example, the OP is using RequestID: 12 and ScalingFactor: 1 https://www.evolutionm.net/forums/ec...ial-cable.html
In this example, the OP is using RequestID: 3C and ScalingFactor: 10 https://www.evolutionm.net/forums/la...o-evoscan.html
What should I be using?
I dont know what you mean, my question has nothing to do with a formula. Wideband will be wired directly to the 73 pin in the ecu.
He is suggesting you use the output signal from the gauge itself to measure AFR vs taping into a pre-used output and altering the formula to get "somewhat" accurate results. Directly from the source via serial/usb and you will be getting fast, accurate results.
Seriously? Nobody will take 2 min out of their day to see what RequestID and ScalingFactor they are using in evoscan?
You need to log "External Wideband o2" in evoscan.
It will display live actual afr to the laptop only.
select COM port, make the USB to serial cable adaptor (local electronics/hobby store) to connect directly to the gauge serial output..
This way the ecu doesnt know the actual AFR, only the laptop.
Actual AFR is not needed by the ecu anyway as it works based off calculated load and is pre programmed via MAF scaling. adding the wideband reading to the ecu and then messing with it to attempt and make it read accurately and on time is the stupid way around it in my opinion. as the guys above suggested.
FFS, idk why i need to say this again but let me repeat... 1) I do not want to use the serial cable method. 2) It can easily be made very accurate.
