Everything to know about evo 8/9/10 OEM wheels
Old Jun 17, 2019, 01:37 PM
DontStopMe's Avatar
UPDATE: Spreadsheet of Information:
https://docs.google.com/spreadsheets...it?usp=sharing
Hello EvolutionM. I want to make a video (Boosted Films) about all the OEM (USDM) evo 8/9/10 wheels. Hoping for some help from the community.
Year - Wheel Options:
2003 - 1) evo 8 Enkei only
2004 - 1) evo 8 Enkei only
2005 - 1) evo8 Enkei 2) evo 8MR bbs's
2006 - 1) evo9 Enkei 2) evo9MR bbs's 3) evo 9SE bbs's
2008-2014 - 1) GSR Enkei & 2) MR bbs's
2015 - 1)GSR Enkei 2) MR bbs's 3) FE Enkei
So there are basically 6 different wheel options from 2003-2015.
3 Enkei's:
1)evo8
2)evo9
3)evo10 (FE option would make 4)
3 BBS's:
1)evo 8/9 MR
2)evo 9 SE
3)evo X MR
Questions:
1) Did i miss any wheels?
2) What would you like to know about these wheels if I was to compare them all?
3) Is it safe to say all evo x wheels would work on a evo 8/9?
4) If no to question 3, whats ones are all compatible?
I hope to answer all these question myself soon. But I know this community has a lot of knowledge to share to help out.
I currently own all the enkei wheels (minus the evo X FE), but I want to buy all 3 BBS options if anyone has 1 wheel of each to sell.
Thanks!
Wheel specs:
Evo 8 Enkei:
size: 17" x 8"
offset: +38mm
bolt pattern: 5x114.3
centerbore: 67mm
weight: 20.50lbs
stock tire size: 235/45/17
Evo 8/9 MR BBS:
size: 17" x 8"
offset: +38mm
centerbore: 67mm
weight: 17.74lbs
Evo 9 Enkei:
size: 17" x 8"
offset: +38mm
centerbore: 67mm
weight: 20.17lbs
Evo 9 SE BBS:
size: 17" x 8"
offset: +38mm
centerbore: 67mm
weight: __
Evo X Enkei (GSR)
size: 18" x 8.5"
offset: +38mm
centerbore: 67.1mm
weight: 22lbs
stock tire size: 245/40/18
Evo X BBS (MR)
size: 18" x 8.5"
offset: +38mm
centerbore: 67.1mm
weight: 18.5lbs
The following 2 users liked this post by DontStopMe:
MinusPrevious (Jun 18, 2019), mr.Freddy (Sep 15, 2023)
Old Jun 17, 2019, 04:23 PM
Hey Paul
Ill comment on:
No.3 = I ran the EvOX GSR's on my 9 for 2 years or so. The wheel size is: : 18x8.5" ; +38 offset ;5x114.3 ; 67.1mm centerbore
AFAIK, all the X wheels were built in that size
And yes, they are a true x-over fit-up on the CT9A. Obviously Brembo friendly. I ran a Toyo 255/35. No rear fender work required unless you run a 265 series (would need some neg camber or a roll)
Joe
DontStopMe (Jun 18, 2019)
Old Jun 17, 2019, 10:21 PM
llDemonll's Avatar
Originally Posted by DontStopMe
3 BBS's:
1)evo 8/9 MR
2)evo 9 SE
3)evo X MR
MR SE is not a "real" trim, it's technically just an MR with an appearance package. the SE wheels are the ones that are different (the light mercury silver color)
Old Jun 17, 2019, 11:14 PM
deylag's Avatar
bbk?
There are the Gray BBS wheels from 2005 Evo 8 MR.
It would be beneficial to throw in the wheel weight of each type of wheel.
Old Jun 18, 2019, 05:58 AM
DontStopMe's Avatar
That is were i'm a bit torn if it should be treated as a different wheel or not.
Were the evo 8/9 MR SE BBS (black diamond) wheels only available on the evo9's? I think so...
while the 8/9 MR BBS's (gray) wheels could come on the 05 evo 8's and the evo 9.
Old Jun 18, 2019, 05:59 AM
DontStopMe's Avatar
Originally Posted by deylag
bbk?
My bad. always meant BBS.
I hope to get the weight of all wheels for comparison.
Old Jun 18, 2019, 06:12 AM
DontStopMe's Avatar
I've heard evo 8/9 17" wheels will not clear evo X brembos. Can anyone confirm?
Old Jun 18, 2019, 07:06 AM
There are a few threads out there confirming the non fit of the CT9A wheels on the X
Heres one post from our Robevo noting they do not fit due to the larger rotor (post no.3)
https://www.evoxforums.com/forums/sh...d.php?t=306050
Old Jun 20, 2019, 04:02 PM
llDemonll's Avatar
It's not an MR SE, it's just an SE
And yes, I'd consider it a different wheel than the gray MR wheels
DontStopMe (Jun 21, 2019)
Old Jun 21, 2019, 07:19 AM
heel2toe's Avatar
Worth noting there is a slight difference between the MR BBS wheels and the SE BBS wheels aside from color. The inner barrel has a different design; this was discussed on here somewhere recently along with pictures. There is a chance the weights of these wheels are slightly different as well.
Old Jun 21, 2019, 09:36 AM
DontStopMe's Avatar
Exactly the stuff i hope to look for and document. Thanks!
Old Jan 12, 2020, 06:37 AM
DontStopMe's Avatar
Not sure if it's worth making a video on this, but I did create a spreadsheet.
Old Jan 13, 2020, 05:24 PM
deylag's Avatar
Are you going to tackle the JDM and UKDM wheel options?
Also what about Evo 7 wheels?
Old Dec 10, 2020, 06:56 PM
DontStopMe's Avatar
Adding some visual to this
Old Dec 24, 2020, 01:55 AM
MEvo_IX's Avatar
Hello, everyone.
I have bbs rims but the valves caps are no longer the original.. someone would know where I can buy some?
Merry Christmas
Quick Reply: Everything to know about evo 8/9/10 OEM wheels
