Tephra / Spark cut patch not working
Old May 9, 2026 | 05:49 PM
JaymeF12's Avatar
Recently got Tephrav3 56910309 rom and have been messing around with the launch timing and fueling maps. however i noticed in the logs that adjusting the timing and fueling does nothing. my timing stays mid to high 20s and fueling stays above 14.7 AFR. I have the factory 2 step limited set to 6k and the spark cut patch set to 4.5k.
Is there anything Im missing that those tables arent impacting my launch values? like is there a setting i need to enable in the tephra rom?
Old May 10, 2026 | 03:48 PM
jmcbrown's Avatar
Send the bin file to fix it my email
jmcbrown146@gmail.com
Old May 11, 2026 | 03:11 AM
JaymeF12's Avatar
any chance you can explain it on here how to fix it as im sure if other people run into the issue they can easily resolve it?
Old May 11, 2026 | 03:26 AM
jmcbrown's Avatar
[QUOTE=JaymeF12;11990516]any chance you can explain it on here how to fix it as im sure if other people run into the issue they can easily resolve it?[/QUOTE
Friend, if you want solve this issue send the file , otherwise you are free, i don't have time to explain there is many task i work on it
Old May 11, 2026 | 01:29 PM
Mondalee's Avatar
I'm co asking
raahul2008
Apr 24, 2024 07:58 AM
VRP
May 12, 2015 12:12 PM
mrfred
Sep 19, 2010 07:32 PM
Boosted Tuning
Jul 16, 2010 11:25 AM
