Anybody running -3 deg w264/264 cams
Old Jan 18, 2004 | 12:42 PM
3deep's Avatar
Anybody running -3 deg with 264/264 cams and gears.I know stg 1+ runs -2 and stg 1 runs -5.
Old Jan 18, 2004 | 01:09 PM
shiv@vishnu's Avatar
Re: Anybody running -3 deg w264/264 cams
I know of two. What's yer question?
shiv
Old Jan 18, 2004 | 01:30 PM
3deep's Avatar
Is there any improvement between -2 and -3 with hks cams
Old Jan 18, 2004 | 01:38 PM
Honestly, most of our testing has been with 264/272 and 272/272 combos. With them, there is certainly an improvement with retarding them both 2-3 degrees. We've only tested a couple of 264/264'd cars... not enough to make a blanket statement. But the two cars we've tested under somewhat controlled environments also benefited from the slight retard.
Shiv
Old Jan 18, 2004 | 04:04 PM
nastea's Avatar
so would a 3 degree retard only apply to your tunes or would be your recommendation across the board
Old Jan 18, 2004 | 04:45 PM
I've seen these settings help even without additional tuning so yes, I'd recommend them FWIW
shiv
Old Jan 20, 2004 | 03:10 PM
BadBoyBeltran's Avatar
I have mine at -2/-2 and it pulls hard. When I had them at TDC, it seemed like the power was there, but it was bottlenecked or something. I am not sure if I was just not opening the throttle wide enough or if they really needed the cam gear adjustment. Now it really roars!!!
Cam Gears.
Attached Thumbnails Anybody running -3 deg w264/264 cams-dsc00010.jpg
Old Feb 17, 2004 | 04:46 PM
Aby@MIL.SPEC's Avatar
Shiv
Could you please post up a power compare of the 264/272 cams with gears straight up vs -2/-3 deg on 91 octane.
Old Feb 17, 2004 | 09:31 PM
boostedwrx's Avatar
I have mine set at -3/-3. I figured it would just move the power band up just a c*nt hair more than -2/-2 would.
