Help! I cannot load the evolutionm website from my home computer!!?
Starting from 2 days ago, this evom website doesnt
load anymore for me from my home computer. I have
tried to enter any address/link that pertains to this
website, but still nothing. I cannot view or even
attempt to log in. Could someone shed some light on
why this might be happening, or possibly on how to
correct this problem?
I havent changed any settings on my home pc, nor have
downloaded any new programs. I am still able to view
and log into other websites without any problems from
home. This website does work on other computers
outside my house
outside my house
this is what i get when i try to log in from my home pc
http://www.google.com/hws/dell-inc/a...nm.net/forums/
http://apps5.oingo.com/apps/domainpa...AyAAMNPvoAM4DQ
To ping, go to start > run, type in command and hit enter. This should bring up a command prompt consisting of a black box and a file path. Then type in "ping evolutionm.net" Then hit enter. If it says destination unreachable, or request timed out, or something of that nature then you have an issue.
+1 on the firefox, i cant stress enough how much safer it is than IE at the moment
thanks for the quick responses
1. tried the ip address 216.193.220.4
but no luck
2. disabled my firewall - still nothing
3. firefox gives me this
The connection has timed out
The server at www.evolutionm.net is taking too long to respond.
* The site could be temporarily unavailable or too busy. Try again in a few
moments.
* If you are unable to load any pages, check your computer\'s network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
4. tried the ping - the result =
Request timed out X 4
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
So I guess I have some sort of issue...
but no luck
moments.
connection.
but no luck
moments.
connection.
but no luck
moments.
connection.
If you get no response that means you have no Internet connection
Originally Posted by Az3ar
Try to ping another site like yahoo.com
How many computers do you have at home?
Does this happen on more than one computer?
Are you able to ping 216.193.220.4?
I can ping yahoo or any other address that I use except evom.
I disconnected then reconnected the modem after a few minutes, but still no change.
I only have one computer that I use, but I am thinking about hooking up my old pc to see if I can get this website to load. I gonna guess no.
I still get the \"request timed out\" when ping evolutionm.net or their ip address 216.193.220.4
I am successful in logging on from another computer outside of my house. I am going to try again on yet another different computer / location to see what will happen.
Could the evolutionm website be blocking my computer\'s ip address?
or
Would a block from \"some website\" on someone\'s ip address cause a similar result?
or
or
or
Can you do a traceroute from the command prompt?
tracert www.evolutionm.net
and
tracert 216.193.220.4
do they both time out somewhere or get "unable to resolve target system?
yes both tracerts get a \"Request timed out.\" along with three \"* * *\" at number 14 , and then again at the numbers 20 - 30.
I\'m going through the same thing right now as well. IP resolves just fine, but no response to pings, telnet on port 80, doesn\'t matter what computer I\'m on here. I am able to browse via proxy, but I shouldn\'t have to do this.
