Evo X Partout is On
I'll take: The AMS 02 housing/Downpipe and I've got the stocker. Also I've got a stock FMIC if you need one with about 1k miles on it from my 2010, maybe we can work something out on that + cash for the downpipe. let me know man and sorry to hear about the partout
It's this kit: https://www.evolutionm.net/forums/ev...-tank-kit.html
I have, and recommend, wiring it slightly different though so that the in tank runs on 12v and the surge tank pump runs switched (the way the stock setup runs).
Installing this will likely require a tweak to your tune, just a heads up.
I'll take
T1R turbo UICP outlet
T1R UICP & LICP
$150 for all of it
Fuel pump assembly with a walbro 255 (e85 compatible, would just swap with a stock assembly)
$100 + your stock assembly
Schrothe rallye 4 harnesses (passenger and driver), includes the shoulder pads
$250 (if it doesnt need a harness bar
maybe thi also if the harness does not go thru
DW 1000 cc injectors (I'll need a clip from a stock injector)
$300 + a clip from yours
T1R UICP & LICP
$150 for all of it
)maybe thi also if the harness does not go thru
I'll take
T1R UICP & LICP
$150 for all of it
T1R UICP & LICP
$150 for all of it
coilover dibs, but I want to know about the blown struts. What happened? will this happen again/often? I dont want to buy a part that is going to cause problems on the track...
also, if you're wanting stock exhaust/fmic so you can outright sells yours, I have them in my garage. I figure we can work out a deal for my exhaust/fmic + some cash for your coilovers and new struts...... let me know sir
What happened is that I didn't drive the car like gramma. Lots of autocross is likely the cause.
Most track struts are rebuilt on a yearly basis (if not more frequently). If these were just street driven they'd likely be just fine.
Marked as well! Thanks!
