Fynetune's 610awhp Evolution VIII
STAGE 1 KIT FOR FYNETUNE IS ALMOST COMPLETE AND WANTED TO SHARE THE TEST RESULTS.
THIS IS A GT40 TURBO RUNNING C16 ON STOCK BOTTOM END AND HEAD WITH HKS 280 CAMS AND HKS CAM GEARS @ 33psi. WE ARE IN FINAL DEVELOPMENT WITH THIS KIT AND WILL CONTINUE TO SHARE NUMBERS WITH YOU GUY'S. ENJOY THE RESULTS FOR NOW.... http://www.fynetuneperformance.com/dynoruns/610awhp.jpg |
jesus... stock bottem end? sick
Good mother of the lord.... what happens after 6700 rpm?
Wow thats ungodly...how are you able to run 280's on stock valvetrain? Or is this just to prove dyno numbers and not streetability/reliability. Those stock springs wouldn't be able to withstand the cam grinds on the 280's for too long IMHO.
Before we where using 272's and notice that the cams where worn a lot but when we checked the spring tension they seemed to be fine. We have quit a few cars running on the stock springs remember the only difference between the cams is the duration, the lift is pretty close to the 272's and 264's. Drivability is more than fine even with these cams; I have not really noticed any difference in drivability from the 272's. However we are looking to go to ferrera valve springs sometime soon.
Cool, OK, How much???????
Well have numbers soon. I will post when kit is fully ready and available. We are trying our best to make this kit very close to the cost of a GT35R kit...
What's the time frame?????
another 2 - 3 weeks granted there are no fabrication issue's that need to be addressed..
well, one thing is for sure, you know how to make decent top end power, especially on a stock block, but something has got to be done about the bottom end power. Just as an example, on less boost, I make about 70hp more @ 6500, and over 300hp and 300ft/lbs more at 5000rpm with my 35r. all this on 29lbs of boost.
reason for that is stock compression is stock 9-1 ours has been lowered quit a bit with the 1.5mm toda head gasket we put on. We are still tuning and will share as we progress... Your forgetting as well from what I see your motor is a 2.4 vers a 2.0
I am confused, Cause stock compression is 8.8:1.
so what will a 1.2mm headgasket do for compression?
those numbers will be good for 10's
| All times are GMT -7. The time now is 01:27 PM. |
