Charleston EVO'S!!!!!!
I need HELP!!
I just had some Cams, MBC, BOV, LICP ect...... installed at GSC. on my way home my car died. I thought it was loose IC piping but it wasnt..... it turned out that my intake heat shield cut through some wires, all that is fixed now but the car still wont start so were thinking now that it may have fried my ECU. does ANYONE have a ECU that i could swap out in my car for 2 sec. to trouble shoot at GSC tomorrow morning-ish?? I could meet you there and do the swap. It would only take 2 min of your time. i just need to know if my ECU is the problem or not. Give me a call if you can help 843-209-5975- Tyler |
What intake heat shield do you talk of that chaffed into the wires? Is it an OEM part, aftermarket, or DIY?
TPayne - I talked to Greg and I can swing by and check it out for you. I have an 03.
Just a bad stream of luck im having i guess. :( |
Any recent news?
If the ecu is good and you need someone to check the wiring I have a meter and contrary to the popular belief Elen can troubleshoot wiring. |
Any recent news?
If the ecu is good and you need someone to check the wiring I have a meter and contrary to the popular belief Elen can troubleshoot wiring. Well i got a call from mitsu yesterday and they said that it is infact my ECU. i have on on its way and it should be here soon. Hopefully that the problem and she starts up. |
I went by GSC the other day, but your car was gone.
did they warranty it? Just kinda curious.
| All times are GMT -7. The time now is 08:37 AM. |
