Rust Protection/Winter Preparation
Krown?? The oil they sprayed my car with was like the same consistancy of cooking oil and I'm pretty sure it doesn't "harden" as my trunk latch is still oily.
What exactly does Pro-Tech seal do??? I supposedly have it done to my car... and I had to go for an inspection recently. But when I look underneath the car... I don't see anything. That's why I'm considering getting the bottom of the car sprayed.
So if I don't see anything under the car... and don't notice any holes anywhere like Krown.... where did they protect... and how did they do it?
The underside is a thick black mastic (rubber) spray that covers all the bolts etc and the interior body panels are coated in greenish clear rubber coating. Hard to explain but you can see it all along my engine bay if you look close enough.
Ill be going to the Krown in Milton sometime soon just for a winter coating.
Is it worth getting Krown done if you got the dealership to undercoat your car when you boat it? Cause the dealership did it to mine back in May but it looks like its only the underside and not the wheel wells and engine compartment and doors like they do with Krown.....
It definitely hardens. If your thinking shell type hardening no.. but it must definitely doesnt stay oily.
Do those things actually work? I was thinking about it... but wasn't sure if it was a gimmick or not. I know they use "cathodic protection" on ships and pipes... but I heard they are operating at a much higher voltage.
One dealer tried to push one of these units on me for like $700!
I saw one for $250 at a place called AutoClass which includes installation and warranty.
Got an email for MotorWorX
$200 for the hard underbody sealent one talked about above.
$70 for dripless rustproofing spray
I voiced a concern that sometimes Krown gets it on the body and although I didnt mind on my prior vehicles I expressed that I had just bought a brand new car and was worried about it. He said they will make it a priority not to overspray and you can watch as its done and look before removing the vehicle from the hoist.
They are located in Vaughan and their email is motorworx@rogers.com
Link to a group buy they have on RFD....
http://forums.redflagdeals.com/2010-...people-789514/
s84kam
Toronto Lancer Club
13
Jul 16, 2009 04:55 AM
