2011 Lancer headlight low beam adjustment
Old Nov 28, 2011 | 05:14 PM
leazua's Avatar
By all means not going to blind ppl in the eye but the low beam on lancer's r quite low..
any1 hav ideas how to adjust them? I think I know where it is but the philip screws on the headlight compartment got a white plastic covering that not enabling me to turn it..
any1 got any ideas??
Old Nov 28, 2011 | 09:31 PM
link627's Avatar
Very easy to do. I was just doing this over the weekend.
http://www.youtube.com/watch?v=5WvCJd1n0-8
Old Nov 29, 2011 | 05:52 AM
leazua's Avatar
I've seen the video before and I know where the knob is to adjust.
The problem is that there's a plastic cap on it that restricting me to adjust.. any1 has the same situation or know how to take the cap off?
Old Feb 18, 2019 | 11:28 AM
jeremy_montoya's Avatar
So, they don't really cover this, but there's a small hole in the front support you can get a long Philips screw driver through. It's tricky, as it's not a screw you're turning, but rather directly sitting on the adjustment gear and using the screw driver to spin the gear. The screw driver will go behind the small metal bracket. you will see the 10mm bolt spin when you turn the gear. So, you don't even need to remove anything, just drop the screw driver in. I did this on a 2013 GSR with Halogens / non-SS, It's pretty hard to spot it, bit if you look down the hole the screw driver is in, you can see the spline on the gear.
tiesto14
14
May 19, 2016 08:52 PM
Tommyy
12
Nov 3, 2015 05:52 AM
2011gts
Lancer How Tos / Installations
Jan 17, 2014 02:10 AM
Wish2345
Jul 19, 2012 08:29 PM
slowx
Feb 27, 2012 08:21 AM
