Spark Tech's COP System gets even better!!!!
Old Oct 23, 2008 | 01:09 PM
  #46
Wicked E's Avatar
Ordered a bracket!! Thanks to you guys for such GREAT products and availability.
-E
Old Oct 23, 2008 | 01:28 PM
  #47
SparkTech's Avatar
Thank you for the order
Old Nov 1, 2008 | 11:54 AM
  #48
SparkTech's Avatar
Here is version 2...we opted to make this an option as V1 could pose clearance issue with 3" intercooler piping.
Old Nov 1, 2008 | 12:47 PM
  #49
MOREPSiTEHBETT4's Avatar
Originally Posted by MOREPSiTEHBETT4
excuse my ignorance, can you explain how this system works and it's benefits over stock? safety?
Old Nov 1, 2008 | 01:18 PM
  #50
SparkTech's Avatar
Inductive Ignition versus CDI Systems
In an inductive ignition system, the coil is charged at battery voltage for a period of time—known as 'dwell time'—prior to firing. The dwell or charge time is controlled by the ECU and should match the coil being used in order to not over or under charge. Undercharging reduces available spark energy, while overcharging can cause overheating of the coil and/or ignition module. Inductive ignition systems produce a spark, at a lower voltage with a longer duration compared to capacitor discharge ignition systems.
A CDI, Capacitor Discharge Ignition system is charging constantly and sends a large voltage charge (380–450 V) to the coil. The spark produced is extremely short in duration and at a much higher voltage than an inductive setup. Note that inductive coils should not be used with a CDI system; CDI compatible coils are required.
There are three main engine running characteristics to consider:
* High cylinder pressures
Generally, higher cylinder pressures require more voltage to initiate a spark. Boosted or nitrous injected engines create tremendous cylinder pressures that increase resistance to lighting the ignition spark. CDI systems are most often used on these engines.
* High RPM
The time available to charge the coil in an inductive system reduces at higher RPM. If the time available is shorter than the time required for a full charge, coil power and, as a result, performance will be reduced. A CDI system might be required.
* Lean mixtures
The shorter spark duration in CDI systems might not be sufficient to ignite enough of the mixture to propagate the flame front through the cylinder. Inductive ignition will perform better in this setup.
Most vehicles, including high performance road and race applications use an inductive ignition system. Generally, if your engine can run correctly on an inductive setup, it is better to leave it that way and install a CDI system only when your engine, due to high RPM or cylinder pressure, requires that you do so.
Old Nov 1, 2008 | 01:19 PM
  #51
SparkTech's Avatar
Didn't mean to leave you out
Old Nov 1, 2008 | 03:49 PM
  #52
very interesting, had to read it a couple times though thank's
I will let my subi buddy know
Old Nov 1, 2008 | 04:54 PM
  #53
SparkTech's Avatar
^your welcome
Old Nov 1, 2008 | 05:54 PM
  #54
dsm25psi's Avatar
how much for v2?
Old Nov 1, 2008 | 08:31 PM
  #55
SparkTech's Avatar
^you have pm
Old Sep 27, 2010 | 10:30 AM
  #56
SparkTech's Avatar
still getting better
Kav@SparkTech
May 21, 2013 08:30 AM
SparkTech
Mar 19, 2012 08:41 AM
Kav@SparkTech
Sep 6, 2010 04:06 PM
SparkTech
Jun 17, 2009 05:05 PM
Kav@SparkTech
Oct 4, 2008 11:21 PM
