Short Block Performance/Race Builds Program! 2.0, Long Rod 2.0, 2.2L, 2.3, 2.4 and
Old Apr 8, 2010 | 12:40 PM
SBR INC's Avatar
Our machine shop has been hard at work building some amazing short and long blocks!
We offer more options for the EVO than anyone else! We were building long rod 2.0s, 2.4L and strokers for as long as I can remember. We have HUNDREDS of motors all over the world and they are kicking some butt!
I'll be posting some of the best combos out there and we'll be posting new deals regularly!
Check out our line up of awesome EVO Short Blocks!
SBR 2.0 Short Block (600hp):
Our first level block is design for anyone looking to build up to about 600hp. This is ideal for anyone with a stock frame turbo, 50trim, gt30ish. They are built to rev and allow you to enjoy your setup. We build these with the OEM short block, OEM 88mm crank shaft and various rod and piston options.
Our most popular 2.0/150mm Rod is:
OEM Short Block
OEM Crank
Manley H Beam Pistons
Manley Platinum Series Pistons (9:1)
ACL Race Main Bearings
ACL Race Rod Bearings
ACL Thrust Washers
Starting at only $2600!
SBR 2.0 Long Rod Short Block (600hp) - Check out this dyno on one of our long rod 2.0 builds!
The long rod 2.0 is an awesome short block. The use of a longer rod with shorter,lighter pistons allows for greater revs! It's a very popular setup that can be classified as nothing short of, AWESOME! It is made up of;
OEM Short Block
OEM Crank
Manley 156mm H Beam Rods
Manley Platinum Series Custom Pistons
ACL Thrust Washers
Keep in mind that as one of the premiere engine builders and distributors around, we have access to some of the best parts in the business at some of the best prices in the business.
We can build to meet any need you could possible have! No matter what kind of internals, compression or demand you have.
WISECO - MANLEY - BRIAN CROWER - CARILLO - K1 - EAGLE - COSWORTH AND MORE!!!
Old Apr 8, 2010 | 01:32 PM
SBR INC's Avatar
Stroke It!!!!
Our strokers have been in some monster EVO's! We use the quality parts, properly prepare the blocks and make sure that they will deliver everything that you need it too!
We have TONS of options for our stroker! Here are just a few samples!
SBR 2.3L Short Block (600hp)
OEM Short Block
Manley 100mm Forged Crankshaft
Manley H Beam Rods
Manley Stroker Pistons
ACL Thrust Washers
Block Machining
Block Clearancing
Starting at $3200
SBR 2.3L Short Block (800)
OEM Short Block
Manley H Beam PLUS Rods
ACL Thrust Washers
Block Machining
Block Clearancing
Starting at $3400
Old Apr 8, 2010 | 01:39 PM
SBR INC's Avatar
Check out our very popular, 2.4L!
We've got several options when it comes to our 2.4! Here are just a few!!!!
1. 600hp Block
-2.4L Block
-Manley H Beam Rods
-Manley 87mm Forged Pistons
-ACL Thrust Bearings
-ACL Main Bearings
-ACL Rod Bearings
-Machined
-Balanced Rotating Assembly
$2499 - NO CORE DUE! (44691)
2. 800hp Block
-2.4L Block
-Manley H Beam PLUS Rods
-ACL Race Main Bearings
-ACL Race Rod Bearings
-Machined
-Assembled
$2699 - NO CORE DUE (44693)
3. Big Power Block
-2.4L Block
-Manley I Beam Turbo Tuff Rods
-Manley 87mm HD Forged Pistons
-Machined
-Assembled
$2999 NO CORE DUE (44694)
4. Optimus Prime of 2.4L Blocks
-2.4L Block
-Manley Billet Crank Shaft
-Manley HD Forged Pistons
-ACL Main Bearings
-ACL Rod Bearings
-Machined
-Assembled
$4199 - NO CORE DUE (44697)
Here is a thread to the an EVO that Mojo/Ivey did with one of our 2.4L and you can see the torque and performance with the FP Black!!!
Check it out!
Old Apr 9, 2010 | 07:18 AM
SBR INC's Avatar
It's FRIDAY!!!! We've got pistons in stock to build just about ANYTHING RIGHT NOW!
It's the last day of the week, let's make a deal! = )
Want a short block ready for final assembly? We can ship it with oil pump, BSEK and more, ALREADY INSTALLED!
Let us know what we can build for you! We want to earn your business.
Old Apr 9, 2010 | 07:41 AM
SBR INC's Avatar
going in for a nice machine job....
Old Apr 10, 2010 | 07:43 AM
SBR INC's Avatar
We have EVO 8 and 9 short block cores coming in! that means we have motors available that don't require a core and will allow for minimal down time!!!
Old Apr 10, 2010 | 11:22 AM
Evo8Master's Avatar
2.4lblock???
What kind of timing belt and water pump do you guys use for the 2.4l block? Is it a custom timingbelt and waterpump or oem? Does the cam timing need to be adjusted for the bigger displacement?
Old Apr 12, 2010 | 08:51 AM
SBR INC's Avatar
the 4G64 belt is used on these. The water pump is just the EVO Pump and the cam timing is going to depend on many factor like HG thickness, how much the head is cut and things like that.
Old Apr 12, 2010 | 08:55 AM
fcapistran's Avatar
This is awesome guys. As soon as im ready for my build, definitely buying one of this from you guys. Awesome seller and deal.
Old Apr 12, 2010 | 08:59 AM
SBR INC's Avatar
thanks buddy,
We've got more and more Mitsu blocks in the works!
Old Apr 13, 2010 | 03:01 PM
SBR INC's Avatar
WE HAVE TONS OF SHORT BLOCK OPTIONS FOR EVERY SINGLE NEED!
Our short blocks are built to handle serious power! This sample block is good to 800hp with the use of our H Beam Plus rod from Manley!!!
EVO Short Block
Wiseco Forged Pistons
Manley H Beam Plus Rods
ACL Thrust Washers
Machined
Decked
Assembed
$3100 - NO CORE DUE!!!!
Old Apr 13, 2010 | 04:26 PM
Force-Fed Performance's Avatar
still waiting on you for the two 2.4's i asked u about marti????
Old Apr 13, 2010 | 05:14 PM
38six's Avatar
How much for a 2.0 build with oem crank, manley 300m & or carrilo rods with cp pistons, for a evo 9 with out the core exchange? Just trying to compare prices with the optimus prime 2.4 build. Also are these new or used cores?
Old Apr 13, 2010 | 05:53 PM
jmelocik's Avatar
Hopefully I'm one of the ones waiting on this!!!! LOL I may have an Evo VIII 4G63 block for a core credit if you need one.
Josh
Old Apr 13, 2010 | 07:16 PM
03lan-evo's Avatar
EVO Short Block
ACL Thrust Washers
Machined
Decked
Assembed
im interested in the price for this.... also do you use balance shaft elim. kits? or is it an option?
