STM -6 valve cover fittings
#31
i cant get a pic of the fitting cause i really dont want to dig through dog poo to get it(bulldogs eat anything that hits the ground it seems) but i can show how this
Gleason text me late last night and he thinks he might have found the fitting brand new from mitsu it so hopefully the problem is fixed soon, now all i need is a motor to put this valve cover on...
#38
Thanks
#39
I know I ran the oem ones last year on a 35r and was fine and all three of the STM cars running nines (9.99-9.27) from last year all ran the same size fittings as well as lots of other evos that were faster then sin. I'd imagine the -6 AN fittings will be fine for you.
#40
Well for a stock motor Im sure its fine but Im bulding my motor in the spring and still running the black turbo. 40psi max. So I most likely need to go bigger. I wouldnt mind the back one being bigger than the side one. PM me with the max sizes side and rear you can make with the stock holes so I dont have to drill. Unless you recommend I need bigger than the stock holes.
Thanks
Thanks
Maybe look into our -6 dipstick tube to help vent the block as well.
-Em
