MIL.SPEC is proud to offer Throttle Body Rebuild Services!
+1!!! Got my rebuilt TB from Aby yesterday, installed it when I got home, took it for a test drive, and couldn't be happier. Possibly the best $100 I've spent to simply improve driveability. Throttle control and response are vastly improved, and I'm sure it's no longer leaking like the stock seals were. I know I'm going to really appreciate not having to pump the gas pedal before starting the car anymore in the morning to loosen up the sticking throttle plate!!!!
Yesterday I changed the BISS seal and idle improved a lot. Yet, the car runs even with the BISS fully screwed in, so it looks like the throttle plate is leaking. A rebuilt tb will solve that?
I have this weird idle problem. When coasting (neutral) and coming to a stop my idle would drop to 500rpm as if I were going to stall but then it catches itself and idles normally. I'm wondering if switching out the throttle body would help me out. I was told maybe my IAC was bad.
Just ordered a 65mm jobby a couple days ago. Can't wait to get it installed! Aby@Mil.Spec was very nice and on the ball! Will update when I get a first impression of the unit, I'm sure it will be dope!
I'm probably going to have to get a Buschur ported stock intake manifold to complement it now. Once I get my GSC s2's and valve springs installed I will have everything I need to push the stock turbo on e85 to the limit. Hoping for some good numbers at the strip!
