MIL.SPEC is proud to offer Throttle Body Rebuild Services!
#31
Got my mil.spec 65mm tb last week. All I can say is awesome. I have 0 boost leaks now. Car feels much better now. I would recommend anybody get this. You won't regret it. Thanks to Aby, he was very friendly and quick to get it out to me. Would definitely buy from again.
#32
1 Post
Abby or Eric, or anyone...right in the middle of changing my seals and I bent the TB Shaft C clip. Anyone know the size? I need to try to get one tomorrow from a shop.....is it a dealer only type part or would a Fastener store have it?
#40
Are the rebuild kits still offered? I don't see it on the website.
I did a boost leak test several months ago and found my throttle body was leaking. At idle evoscan showed only 15 inhg of vacuum. I thought the leak was at the little screw area, but figured it was probably shaft seals. I did this repair on my eclipse years ago. After the repair vacuum jumped to 22, which is what my eclipse reads also. I was happy. I ordered the mil.spec seals through stm, or the works version. I don't recall and both are in my notes.
The problem I was still chasing, crappy boost response, still remained. I did another boost leak test today. I am 100% sure this is the IAC warmup flapper o-ring.
Considering the seals are $25, I guess the kit is no longer $30. If it is no longer offered, what is the current turn around time for rebuild on an evolution 8 throttle body.
#41
I have this weird idle problem. When coasting (neutral) and coming to a stop my idle would drop to 500rpm as if I were going to stall but then it catches itself and idles normally. I'm wondering if switching out the throttle body would help me out. I was told maybe my IAC was bad.
#45
1 Post
PM me instructions on how to purchase the whole OEM rebuild kit shipped to 33872, include the paypal address, it is for an 05 evo stock throttle body.
