Buschur Racing brake booster delete/manual brake kit.
Old Dec 1, 2012, 12:49 PM
booSted37r's Avatar
does this kit work on evos with abs an acd? doesn't deleting the abs mess up the acd an throw a cel
Old Dec 2, 2012, 10:03 AM
whiteEvo08Y's Avatar
Hey David.
Do you have this kit in-stock and ready to go?
If not, how long for build time?
Old Dec 3, 2012, 08:05 AM
David Buschur's Avatar
If you have ABS skip this kit. This is what I'd consider a "race" brake set up. Yes it works great on the street but if you want to eliminate a brake booster for more room or weight etc., then deleting the ABS should be on that same list.
Yes, we have the kits, we do have to put them together, ship time is less than a week.
Old Dec 3, 2012, 09:44 AM
mullen's Avatar
This part is top notch, I have seen them on a hand full of cars and it is super clean. It will take some getting used to but the fact is THE CAR STOPS FINE WITHOUT POWER BRAKES.---> Badbish, Streetthisevo, and a bunch of other names are using them
I think people are too hesitant to leave power brakes because it's all they know. Years ago cars used to be manual brakes and they stopped fine on drum brakes. Power brakes didn't become "standard" until disc brakes. I am seriously contemplating this kit as one of my next upgrades on my car and if you're serious about weight reduction, a simple/clean look, then you should consider it as well...
Old Dec 3, 2012, 05:47 PM
booSted37r's Avatar
I'd order this kit today I just need to know if it will affect the acd an throw codes for the abs if deleting pump.
Old Dec 4, 2012, 06:27 AM
I'm going to go out on a sturdy limb and say, YES it's going to effect those. That's why I just stated if you want to keep those things it's not for you.
Old Dec 4, 2012, 06:47 AM
Also is this kit pain in the a#$ to install if the motor is still in the car? OR do you prefer it will be alot easier with the motor out David?
Old Dec 4, 2012, 07:43 AM
There are some pictures of Nick's car having parts installed on our Facebook page right now. The master install is easy with the engine in. You do have to make all the brake lines which is a bit of a time consuming ordeal but I did mine with the engine in and we'll be doing this one with engine in too. Easiest thing was to cut the stock lines and just take them out, which is what we did on Nick's car. Link to our Facebook page are below.
Old Dec 4, 2012, 08:23 AM
mullen's Avatar
By deleting the abs, will the labs light stay on? If so can it be turned off through the ecu?
Old Dec 4, 2012, 08:29 AM
If you delete the ABS there is no light that we can recall and we've done quite a few.
Old Dec 4, 2012, 08:34 AM
mullen's Avatar
Good to know! Thank you
Old Dec 4, 2012, 11:06 AM
Evo_AK's Avatar
For those with ACD that want to remove ABS, follow this guide:
https://www.evolutionm.net/forums/ev...ayc-guide.html
Old Dec 27, 2012, 03:25 PM
booSted37r's Avatar
That doesn't work for the Usdm evos. We don't have ayc
Old Jan 6, 2013, 01:02 PM
flyingscot's Avatar
really interested in this,i have a question David,i have abs right now and i will be deleting it,will i still need to source the rs brake lines ?
Old Jan 7, 2013, 07:11 AM
No you do not need the RS brake lines when doing this kit.
Quick Reply: Buschur Racing brake booster delete/manual brake kit.
