Buschur Racing brake booster delete/manual brake kit.
#31
"Buuster... I doon need no stiinkin' buuster"
My old porsche (por sha) has disk brakes, no booster. Your brake leg does get massively built and you'll look funny in shorts with your left tooth pick leg.
Also, walking a straight line becomes a bit harder but you concentrate and compensate by taking a longer stride with your tooth pick leg.
Cheers,
Cheers,
#35
#40
If you have ABS skip this kit. This is what I'd consider a "race" brake set up. Yes it works great on the street but if you want to eliminate a brake booster for more room or weight etc., then deleting the ABS should be on that same list.
Yes, we have the kits, we do have to put them together, ship time is less than a week.
Anyone else run this manual brake / booster delete kit that can provide additional feedback ? How much “firmer” is the pedal with this kit ? I guess from a scale of “brake booster vacuum line popping off firm” really firm to “brake booster functioning correctly” easy , where does this fall ? Any other input ...?
MisUnderStood
48
Oct 3, 2017 07:57 AM
Rob_GPT
15
Nov 8, 2016 02:52 AM
e_kobz
13
Nov 17, 2015 09:24 AM
badev0
Nov 13, 2015 05:51 PM
Eno-Evo
Oct 13, 2015 10:48 AM
