EnglishRacing now offers 8/9 ACD tuning
#46
I've already posted my thoughts on it, but I haven't seen any negatives and immediately started shaving large chunks of time on the track. I highly recommend their tune. Also worth mentioning they had good customer service, kept in touch about the progress and tracking of the ACD.
#49
can't wait to try this out with the setup changes i've made this year
#50
Just ran my first competition event with the Evo set up properly. The car moves around very, very nicely and each ACD setting is a significant change from the other. For me, in an autox setting, I'm overall getting a lot more rotation from the car - I've actually set the shocks to understeer a little more so I can run the Gravel (Track) setting for autocross. The Tarmac (Autox) map may be more optimal for r-comp tires, which I am on street tires.
A must for any competition evo
#53
just saw this post in the acd tuning mega merge:
Well I've had the ER tune for awhile now so I feel I can confidently give a good review on it. I have the 3 map like kyoo, however I believe the snow mode is a little more aggressive than the stock Tarmac mode.
Just for reference, I only do road course, no auto cross, and have been running stock size RS3 version 2s the entire time. Power is at about 330hp 330tq to the wheels.
Initially I was on stock suspension with a restacked stock diff. On the street the difference was night and day. Every mode made a massive difference and cornering was dramatically improved. Just dial in the oversteer you'd like. On the track the difference was not so dramatic. The car was a little more balanced but switching modes didn't seem to change much.
Fast forward a little bit and I'm running ohlins, whiteline pretty much everything, Perrin psrs with castor offset and whiteline rsb. I've now gained the same effect on the track that I initially had on the street. Just dial in the rotation with a button on the dash. I set it low on open sweeping sections and bump it up for the tighter areas where I need a little more rotation. I couldn't be happier.
In addition English Racing was awesome to deal with and really takes customer service seriously. They will be hearing from me again when it comes to beefing up the power.
#58
bumping this. i had someone who trophied at solo nats in a similar turbo awd car come away stunned at how the car handled. said the rear end steps out perfectly with zero fear of it biting. also said the on-power push from the rear is really tangible, just a hint of oversteer on power. we bumped it to the most aggressive setting and they were stunned at the difference even that made.
if you guys are tracking/autoxing your cars and haven't gotten and ACD tune, you are missing out.
I've tried Gruppe-S, ACD Tuning, and English Racing. None of the tunes has made a difference like ER's has, no exaggeration. the USDM 8/9s need this to fix their awd setup.
http://www.motec.com/filedownload.ph...pdf?docid=4399
