Comming Soon Peak Performance Pillowball Mounts
Comming soon from Peak Performance . Adjustable Upper Pillowball Mounts. These mounts are made from 8mm T6061 Aircraft Aluminum.
The rubber bushing is replaced with a pillow ball which eliminates the load input compliance, and reduces the change of alignment to improve the grip of the tire. Anodized finishes provide maximum strength and durability against corrosion. Lightweight plates (22.oz) provide up to +/- 39mm of camber adjustment in the front and +/-32mm of camber adjustment in the rear (rear camber adjustment only available on wrx). A perfect upgrade over the soft oem mounts. Estimated Delivery Date Mid March 2008 MSRP Front-$220 Rear-$180 http://www.gruppe-s.com/Ben/Suspensi...mounts_wrx.jpg http://www.gruppe-s.com/Ben/Suspensi...ounts_evo9.jpg http://www.gruppe-s.com/Ben/Suspensi..._evo9_lowe.jpg http://www.gruppe-s.com/Ben/Suspensi..._installed.jpg |
bump!
Nice!!!!
Yes! we are very excited for these to become available, the prototypes are awesome!
Bump!
Bump!
Bump!
come on tax refund !!!!!!!!!!!!!!!!!!11 :) will you guys offer a package deal discount ?
Originally Posted by ~EVILEVO~
(Post 5280013)
https://www.evolutionm.net/forums/sh...d.php?t=324794 KW Variant 3 Coilovers Free Peak Performance Pillow Ball Top Mounts http://www.gruppe-s.com/Ben/Suspensi...AT_SPECIAL.gif The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers. True 2 way. Independently adjustable damping technology -rebound and compression damping. Inox-line stainless steel technology. High-quality components for long life. *** Peak Performance Mounts are currentley in the final stages of development. Scheduled delivery date for mounts is aprox 4 weeks away. Coilovers will imediately ship out as soon as the order is placed. Once top mounts arrrive we will ship them out *** Click Here For More Information on the Peak Performance Upper Mounts Peak Performance Pillowball Mounts Pre-Order Now http://www.gruppe-s.com/Ben/Suspensi...ounts_evo9.jpg Comming soon from Peak Performance . Adjustable Upper Pillowball Mounts. These mounts are made from 8mm T6061 Aircraft Aluminum. The rubber bushing is replaced with a pillow ball which eliminates the load input compliance, and reduces the change of alignment to improve the grip of the tire. Anodized finishes provide maximum strength and durability against corrosion. Lightweight plates (22.oz) provide up to +/- 39mm of camber adjustment in the front .A perfect upgrade over the soft oem mounts. $350 Shipped Pre-Order Special Price |
Bump!
Bump!
Bump!
Bump!
Bump!
Bump!
