Nisei Engineering's Evo 8 & 9 Line Up!
MAXUM TECHNOLOGIES is the New MASTER DISTRIBUTOR of NISEI ENGINEERING PRODUCTS!
Here is the FULL NISEI ENGINEERING LINE UP FOR THE EVO 8/9. Everything you see here weve got in stock! PM, email us with any questions/you might have! We'll be checking in as much as possible to answer any questions you might have or you can also email us at Sales@MaxumTechnologies.com. Enjoy! IN STOCK FOR THE EVO 8/9 http://www.nisei-evo.com/images/Misc...titionFMIC.jpg Nisei Engineering Competition FMIC / All hardware included Nisei Engineering has developed and brought about revolutionary designs for the Mitsubishi Evolution 8 and 9 intercooler. Unlike other manufacturers that use existing intercoolers, Nisei Engineering pushed the limits one step further than the competition with a radical approach to intercooler design. Starting completely from scratch, combining racing technology know-how with the RR (Race Ready) method and built an intercooler specifically for the Evolution from the ground up. Core Dimensions - 25" x 12.62" x 3.7" Largest Exposed Surface Area - 25" x 12.62" to maximize cooling efficiency. Polished 3" Inlet / Outlet cast aluminum end tanks - to ensure best fitment and eliminating any chance of leakage at the welds (unlike fabricated sheet metal end tanks). 23 Cooling Tubes - More cooling passages than any other FMIC. Making heat transfer more effective since heat is distributed over more tubes. More cooling tubes equals, more cooling fins to transfer heat out quicker. By spreading the load over more passages allows each Cooling Tube to become more effective by operating at a lower duty cycle. Designed specifically for the Evo 8/9 from the "Ground Up". (Fin geometry & fin configuration) Tested and proven to dramatically reduce/stabilize intake temps especially with stock turbo high boost (24psi) applications : http://nisei-evo.com/forum/viewtopic.php?t=26 / http://nisei-evo.com/forum/viewtopic.php?t=25 Stabilizing/holding inlet temperatures at approximately 10*-15*F over ambient. Holding pressure drops across the core below 1 psi typically between (high - low) .7 psi - . 2 psi (based on stock turbo running 23psi). Designed to support 800 whp. Whether your on the stock turbo or GT40R it's the only FMIC you have to buy once! Fitment - Retains factory crash beam. Works with stock piping or any piping kit which retrofits to stock FMIC. Hardware - All hoses, T-bolt clamps, ready to install. To find out about some intercooler basics check out this tutorial : http://www.niseiengineering.com/imag...erTutorial.swf http://niseiengineering.com/images/NiseiSpRPipes001.jpg http://www.niseiengineering.com/imag...iBlack0506.jpghttp://www.niseiengineering.com/imag...Polish0506.jpghttp://www.niseiengineering.com/imag...seiRed0506.jpg Nisei Engineering 6061 Aluminum Evo 8/9 Pipe kit / Model 2005 - 2006 / Available in : Nisei Red, Nisei Black, Polished / ALL HARDWARE INCLUDED Made from 6061 Aluminum. CNC Mandrel Bent, to ensure accurate bend angles, highest quality & best fit. Direct routing design - shortest, straightest path to increase throttle response. Only pipe kit fully compatible with factory air box & FMIC! BOV - Works with factory BOV or any BOV which retrofits with stock piping. Aftermarket BOV flange can be added by request ( TiAl, HKS Greddy, etc. ). Complete kit weighs less than 4 1/2 lbs including pipes, hoses, and hardware. Powder Coated for flawless & durable finish. Kit includes : All Pipes, LICP (turbo-FMIC), UICP (FMIC-Throttle Body), T-bolt Clamps, Nutsert (Airbox), BOV extension, HOSE TECHNIQUES: Multi Ply Silicone Couplers (carry Lifetime Warranty), all hardware for immdiate installation! Colors available : Matte Black, Nisei Black, Nisei Red, Carbon Gray, and Polished. Requirements : Use of a mini battery kit or trunk relocation! http://www.niseiengineering.com/images/NiseiKit06.jpg http://www.niseiengineering.com/imag...iBlack0304.jpghttp://www.niseiengineering.com/imag...Polish0304.jpghttp://www.niseiengineering.com/imag...seiRed0304.jpg Nisei Engineering 6061 Aluminum Evo 8 Pipe kit / Model 2003 - 2004 / Available in : Nisei Red, Nisei Black, Polished & Carbon Gray / ALL HARDWARE INCLUDED Made from 6061 Aluminum. CNC Mandrel Bent, to ensure accurate bend angles, highest quality & best fit. Direct routing design - shortest, straightest path to increase throttle response. Only pipe kit fully compatible with factory air box & FMIC! BOV - Works with factory BOV or any BOV which retrofits with stock piping. Aftermarket BOV flange can be added by request ( TiAl, HKS Greddy, etc. ). Complete kit weighs less than 4 1/2 lbs including pipes, hoses, and hardware. Powder Coated for flawless & durable finish. Kit includes : All Pipes, LICP (turbo-FMIC), UICP (FMIC-Throttle Body), T-bolt Clamps, Nutsert (Airbox), BOV extension, HOSE TECHNIQUES: Multi Ply Silicone Couplers (carry Lifetime Warranty), all hardware for immdiate installation! Colors available : Matte Black, Nisei Black, Nisei Red, Carbon Gray, and Polished. Requirements : Use of a mini battery kit or trunk relocation! http://www.maxumtechnologies.com/ima...CPCG050602.jpghttp://www.maxumtechnologies.com/ima...CPNB030402.jpg Nisei Engineering 6061 Aluminum Evo 8 UIP Pipe kit / Model 2003 - 2006 / Available in : Nisei Red, Nisei Black, Polished & Carbon Gray / ALL HARDWARE INCLUDED Made from 6061 Aluminum. CNC Mandrel Bent, to ensure accurate bends angles, highest quality & best fit. Direct routing design - shortest, straightest path to increase throttle response. Only pipe kit fully compatible with factory airbox & FMIC! BOV - Works with factory BOV or any BOV which retrofits with stock piping. Aftermarket BOV flange can be added by request (Tial, HKS, Greddy, etc.). Complete kit weighs less than 4 ฝ lbs including pipes, hoses, and hardware. Powder Coated for flawless & durable finish. Kit includes: Pipes: UICP (FMIC-Throttle body), T-bolt Clamps, Nutsert (Airbox), BOV extension, HOSE TECHNIQUES: Multi Ply Silicone Couplers (carry Lifetime Warranty), all hardware for immediate installation! Colors available : Matte Black, Nisei Black, Nisei Red, Carbon Gray, and Polished. Requirements : Use of a mini battery kit or trunk relocation! http://www.maxumtechnologies.com/images/LICPNB.jpg http://www.maxumtechnologies.com/images/LICPCG802.jpg http://www.maxumtechnologies.com/images/LICPPol.jpg http://www.maxumtechnologies.com/images/LICPNR.jpg Nisei Engineering Evo 8/9 6061 Aluminum LIP kit / Model 2003 - 2006 / Available in : Nisei Black, Nisei Red, Carbon Gray, Polished / ALL HARDWARE INCLUDED Made of 6061 T6 Aluminum. CNC Mandrel Bent, to ensure accurate bend angles, highest quality & best fit. 1 pc. Design/Mandrel bent Allowing for smoothest flow possible. Mounting bracket ensures LICP to remain stable while under high boost. Keeping pipe from popping off. Hose Techniquesฎ multi-ply (Lifetime warranty) with T-bolt clamps to ensure secure connection. Color available : Nisei Black,Carbon Gray, Nisei Red, Polished Fitment includes : Evolution 7/8/9 Complete with all hardware Will work with stock FMIC. (Any FMIC that is compatible with stock plumbing) http://www.maxumtechnologies.com/images/LICP1018.jpg Nisei Engineering Evo 8/9 1018 Steel LIP kit / Model 2003 - 2006 / Available in : Nisei Black / ALL HARDWARE INCLUDED http://www.maxumtechnologies.com/ima...eiBlack001.jpg Nisei Engineering Genesis Mini Battery Kit / CNC Billet 6061 Aluminum / Evo 8/9 Model 2003 - 2006 / Available in : Nisei Black, Polished, Nisei Red / Enersys Genesis Battery, TERMINALS & ALL STAINLESS MOUNTING HARDWARE INCLUDED Made from 6061 T6 BILLET Aluminum. CNC Machined for the perfect fitment. Genesis Tray Starts as a 1 thick billet plate, which is then CNC Machined to creating a retaining wall around the battery. Allowing the battery to sit inside the Genesis tray assembly or pocket, keeping battery stable. Secured Fit! Nisei Engineering is ONLY kit fully compatible with OEM Air Box! Tray also features 3 recessed locating/mounting holes to allow for trunk relocation or universal mounting applications. Full Kit includes : Genesis tray assembly, Enersys Genesis Battery, Brass Terminals, ALL Stainless Steel hardware! Everything needed to install into Evo 8/9 in about ฝ hr. Colors : Nisei Black, Matte Black (Limited Production), Nisei Red, Polished, Carbon Gray. Compatible with : Enersys /Hawker Genesis 16EP, Odyssey PC680 or any battery with dimensions of L = 7.27 x W = 3.11 x H = 6.67. NOTE : Will NOT work with PC680MJ model See Nisei Engineering Mini UBC Kit. http://www.niseiengineering.com/images/UBCNB.jpghttp://www.niseiengineering.com/images/UBCPol.jpg Nisei Engineering UBC Mini Battery Kit / CNC Billet 6061 Aluminum / Evo 8/9 Model 2003 - 2006 / Available in : Carbon Gray, Nisei Black, Polished / Enersys Genesis BATTERY, TERMINALS & ALL MOUNTING HARDWARE INCLUDED Made from 6061 T6 BILLET Aluminum. CNC Machined for the perfect fitment. UBC Tray Starts as a 3/8 thick billet plate, which is then CNC Machined to shape. The UBC tray assembly utilizes 2 side brackets to keep the battery in locked into position. Nisei Engineering is ONLY kit fully compatible with OEM Air Box! Tray can also be used to relocate battery to trunk. Full Kit includes : UBC tray assembly, Enersys Genesis Battery, Brass Terminals. Everything needed to install into Evo 8/9 in about ฝ hr. Colors : Nisei Black, Nisei Red, Polished, Carbon Gray. Compatible with : Enersys /Hawker Genesis 16EP, Odyssey PC680, and PC680MJ or any battery with dimensions of L = 7.27 x W = 3.11 x H = 6.67. NOTE : Will work with PC680MJ model. http://www.niseiengineering.com/imag...LineUp0010.jpg Nisei Engineering Genesis Tray ONLY / CNC Billet 6061 Aluminum / Evo 8/9 Model 2003 - 2006 / Available in : Nisei Red, Polished, Nisei Black / ALL MOUNTING HARDWARE INCLUDED Compatible with : Enersys /Hawker Genesis 16EP, Odyssey PC680 or any battery with dimensions of L = 7.27 x W = 3.11 x H = 6.67. NOTE : Will NOT work with PC680MJ model See Nisei Engineering Mini UBC Kit. http://www.niseiengineering.com/imag...LineUp0005.jpg Nisei Engineering UBC Tray ONLY / CNC Billet 6061 Aluminum / Evo 8/9 Model 2003 - 2006 / Available in : Carbon Gray, Polished, Nisei Black / ALL MOUNTING HARDWARE INCLUDED Compatible with : Enersys /Hawker Genesis 16EP, Odyssey PC680, and PC680MJ or any battery with dimensions of L = 7.27 x W = 3.11 x H = 6.67. NOTE : Will work with PC680MJ model. We'll keep an eye out for your emails and questions! Thanks! |
Prices?
Pricing
PM with: item of interest and zip code. |
| All times are GMT -7. The time now is 01:02 AM. |
