-   Vendor Announcements (https://www.evolutionm.net/forums/vendor-announcements-235/)
-   -   SparkTech's *NEW* QUICK DISCONNECT option (https://www.evolutionm.net/forums/vendor-announcements/444997-sparktechs-new-quick-disconnect-option.html)
SparkTech Sep 6, 2009 10:12 AM
http://www.sparktechignitions.net/im.../QD-header.jpg
Introducing Spark Tech's Quick Disconnect Option for the CDI systems.
This option enables users to quickly separate the mounting plate and coils from the balance of the wiring system. This makes changing plugs & other routine maintenance easier as the entire system does not have to be removed or disconnected.
This is a high quality, sealed connector. Designed for high heat, industrial, automotive and marine use. It is specifically designed for power and signal connections. There is little to no signal or power loss.
http://www.sparktechignitions.net/im...O4-9_qdc_6.jpg
http://www.sparktechignitions.net/im.../QDC-EVO_2.jpg
http://www.sparktechignitions.net/im...ms/evotech.png
EvoDan2004 Sep 6, 2009 11:04 AM
i have this and man is it an awesome option. makes taking things apart sooooo much easier. thanks Craig and Spark Tech for coming out with this and adding it to your already bad a$# system.
Viciouslord Sep 6, 2009 07:07 PM
Beautiful.
dsm25psi Sep 6, 2009 09:19 PM
nice i wish i had that
SparkTech Sep 7, 2009 08:53 AM
^That could be arranged:)
Dipz Sep 7, 2009 10:34 AM
Bzzzzzzzz
ericblackevo8 Sep 7, 2009 11:56 AM
Any thing to make it easier on me!:thumbup:
evoracingstar Sep 7, 2009 03:50 PM
how much for everything shiped to 06076 thanks
Indy Evo Sep 7, 2009 04:23 PM
We run that package on the 9sec9 car :)
CWiLL Sep 7, 2009 04:46 PM
Very nice. couldn't expect any less from Sparktech!
ps i need to send you my COP for new plate ill call you later
SparkTech Sep 7, 2009 04:52 PM
pm sent{thumbup}
SparkTech Sep 7, 2009 04:54 PM
CWILL....I've been waiting on you:p
SparkTech Sep 7, 2009 04:57 PM
You guys were the 1st to have this option. It makes plug changes so much easier...not to mention by disconnecting the whole cop plate reduces the risk of damaging a coil.
dsm25psi Sep 7, 2009 05:04 PM
what needs to be done for the new setup?
SparkTech Sep 8, 2009 07:27 AM
^This Quick disconnect is for our Pro version which utilizes the Billet Aluminum mounting plate. It won't be offered for the basic version.
