-   Vendor Announcements (https://www.evolutionm.net/forums/vendor-announcements-235/)
-   -   STM's New part for those with catch cans! (https://www.evolutionm.net/forums/vendor-announcements/464151-stms-new-part-those-catch-cans.html)
EmeryatSTM Dec 18, 2009 11:32 AM
Always looking for ways to make the engine bay cleaner, lighter and easier to work with, STM designed this little, aluminum fitting to allow you to simply install -6AN lines and fittings for a catchcan or breather right onto your valve cover.
As the piece itself is a very tight fit, we would definitely recommend a bit of glue or epoxy to help hold it in place in the valve cover upon install.
http://www.streettunedmotorsports.co...an_fitting.jpg
http://www.streettunedmotorsports.co...n_fitting2.jpg
http://www.streettunedmotorsports.co...n_fitting3.jpg
Compared to the big, hulking mess we previously had to run below.
http://www.streettunedmotorsports.co...n_fitting4.jpg
These can be found here
http://www.streettunedmotorsports.co...evo_engine.htm
Thanks for looking and as always thanks for your support!
Merry Christmas
-STM
silver3g2000 Dec 18, 2009 11:33 AM
Looks CLEAN
EmeryatSTM Dec 18, 2009 05:26 PM
I like it a lot.
Also, Its actually about twice the inside diameter of the stock piece with a fitting attached to it so it relieves quite a bit more crank case pressure without any cutting.
-Em
EmeryatSTM Dec 19, 2009 10:45 AM
We got a lot more of these in this morning! Come and get them{thumbup}
-Em
EmeryatSTM Dec 29, 2009 10:53 AM
up.
e55nEVO9 Dec 29, 2009 10:58 AM
So how do you get the factory piece out? just strong man it out?
EmeryatSTM Dec 29, 2009 06:54 PM
Yes sir. If you twist it, it will come free. Its not to hard at all to walk one out.
-Em
chaotichoax Dec 29, 2009 11:25 PM
Em,
how do you recommend installing your replacement piece since it's such a tight fit?
also what type of epoxy do you suggest?
EmeryatSTM Dec 30, 2009 06:13 AM
Originally Posted by chaotichoax (Post 7841452)
Em,
We just put a dab of silicone on them and tap them in with a mallet. Also, I recommend putting the part in the freezer before install so it shrinks up a bit. The colder you get it the easier it will slide in.
-Em
chaotichoax Dec 30, 2009 07:55 AM
thanks for the tips...I'll probably pick one of these up from you along with some other stuff
Sharkbite2000 Dec 30, 2009 08:00 AM
very nice :)
EmeryatSTM Dec 30, 2009 08:45 AM
Thanks guys.
-Em
EmeryatSTM Feb 3, 2010 12:59 PM
We just got another batch in. Thanks for all the orders guys!
-Em
