-   Vendor Announcements (https://www.evolutionm.net/forums/vendor-announcements-235/)
-   -   Spark Tech's COP UPGRADES (https://www.evolutionm.net/forums/vendor-announcements/607928-spark-techs-cop-upgrades.html)
SparkTech Apr 18, 2012 03:02 PM
Here at Spark Tech we have spent countless hours, improving and perfecting our systems. It is through all the research and testing that we proudly bring you this solution. Many are aware of an annoying part throttle miss/stumble associated with some of the other C.O.P systems on the market. This issue can sometimes be masked in tuning and is often attributed to large cams and heavily modified engines. This couldn't be further from the truth. I've even seen recommendations to increase the plug gaps. This will not rectify or get to the source of the problem. It's all in the wiring. We are proud to be able to say our systems are truly 100% compatible with the stock ecu and standalone ecu's... Not to mention, it looks great! {thumbup} You will be proud to show off your engine bay with this high quality and well engineered product.
If you are tired of excuses and are looking for better driveability, we have a guarantee for you: If this upgrade doesn't make a noticeable difference in the idle quality/driveability, simply return it for a FULL Refund.
These upgrades will work with any system on the market utilizing 300m coils and the M & W Pro-12 cdi (cdi NOT included). These upgrades are 100% Plug and Play. They come with the billet aluminum plate that is featured in our PRO system, that starts off at $1196.17.
We think that your car is as unique as you are. And your ignition should be the same! This is why we offer many different options to suit your various needs. All Spark Tech Upgrades feature military spec wire & heat sleeving, stainless steel hardware and sealed marine grade fuse holders.
1. Spark Tech Complete Upgrade -
This upgrade features 4 brand new coils with 1year warranty. With this upgrade all you need is the M&W Pro-12 CDI Unit. Here is a picture of the complete upgrade with the new coils.
http://www.sparktechignitions.net/EV.../IMG_8695a.jpg
You also have 2 mounting plate finishing options available :
  • Powder coated wrinkle black (standard)
  • Polished (+$45)
http://www.sparktechignitions.net/EV...s/IMG_8698.jpg
POWDER COATED WRINKLE BLACK
http://www.sparktechignitions.net/EV...s/IMG_8699.jpg
POLISHED
http://www.sparktechignitions.net/EV...s/IMG_8700.jpg
Click HERE to view the item in our online store.
http://www.sparktechignitions.net/img-2011/evoM-sig.jpghttp://www.zorce.com/Images/entrySplash/facebook.png
Evostacio Apr 18, 2012 03:39 PM
very nice product guys loving mine
georg1970 Jun 3, 2012 05:29 PM
How much would be CDI for evo 8 + shipping to Russia?
Thanks,
Shota
SparkTech Jun 6, 2012 09:09 AM
^PM sent{thumbup}
SparkTech Jun 9, 2012 04:19 PM
bump
Dynotech Tuning Jun 15, 2012 10:13 AM
Are there any performance differences between the Evo 9 CDI:BASIC and the PRO?
-Jamie
SparkTech Jun 18, 2012 03:40 PM
Jamie they are both powered by the M&W Pro-12 so power wise the answer is NO. However durability/functionality wise YES. Due to the design/budget constraints of the basic system it has some disadvantages. It's wiring is not secured to the mounting plate which over time tugging/pulling on the harness can develop issues. The mounting boots on the basic system has to be cut shorter due to the height difference between coil and top of spark plug. The Pro's coil boots don't need to be cut/shortened.
The Pro systems wiring has built in slack in the wiring and they are secured to the underside of it's mounting plate. This prevents any stress on coil connectors/wiring. The Quick disconnect and Billet coil protectors options are ONLY available on the Pro series.
SparkTech Jun 26, 2012 08:29 AM
ttt
SparkTech Jul 6, 2012 10:12 AM
bump
SparkTech Jul 27, 2012 09:23 AM
bump
SparkTech Aug 29, 2012 11:06 AM
ttt
SparkTech Oct 9, 2012 10:23 AM
bump
SparkTech Oct 26, 2012 07:25 AM
ttt
SparkTech Oct 31, 2012 08:47 AM
Bump
SparkTech Nov 16, 2012 08:48 AM
bump
