Timing Belt Kits Available @ Boostin Performance
https://c1.staticflickr.com/4/3818/3...87e5fd2f_b.jpg
Keep your engine running strong by ensuring you're on top of your maintenance routine. Over time, timing belts wear out, causing the crankshaft to lose sync with the camshaft and the valves. If timing components break, it can severely damage your engine, becoming an extremely costly repair! Save yourself the headache and ensure that your engine will be running properly with a Boostin Performance Timing Belt Kit! Contact us or visit our website to order your BP Timing Belt Kit, available with or without Water Pump https://www.evolutionm.net/forums/im...e_thumbsup.gif https://shop.boostinperformance.com/...&Submit=Submit Contact us for a quote to have your Timing Components Replaced, while you wait in our showroom! Ask us about some of the our other maintenance services we offer, including...... - Drivetrain Fluid Flushes - Oil Filter & Oil Change - Brake & Rotor Replacement - Clutch Installation & Flywheel Resurfacing - Injector Cleaning Services - AND MORE!! |
BUMP !
Changing the timing components is actually part of your maintenance, get it done ! |
Are the components in your timing kit genuine Mitsubishi parts or aftermarket?
Originally Posted by Lumpy Sticks
(Post 11885358)
We use Genuine Mitsubishi timing components. Give us a call if you want to set up anything or if you have any other questions, we would be happy to help. |
Bump !
Visit our website to order your DSM / Evo Timing Belt Kit, or contact us for a quote for Replacement of all Timing Components.
bump
