*STM Evo 7/8/9 Oil Cooler Kits, Standard and Race Size IN STOCK*
Gets yours today at the link below. Use code "shootout5" at checkout before the end of the month and recieve 5% off your order!!!
https://stmtuned.com/products/stm-ev...oil-cooler-kit
Fits these Applications:
2001-2006 Mitsubishi Lancer Evolution VII VIII IX
The Engine Oil Cooler Kit for the Evo 7/8/9 is a direct bolt-on upgrade featuring a custom STM mounting bracket, B&M oil cooler and high-quality hose, fittings and hardware to attach to your factory oil filter housing for a clean and simple install.
Please Note:
The fittings threading into the oil cooler are pipe thread. Over tightening pipe thread will cause things to break. If you are not familiar with it, please seek professional installation.
If you purchased an older version of the STM kit and created your own bracketing solution, you can purchase just the STM Mounting Bracket. The STM brackets are different between the small (Standard) and large (Race) kits.
Features:
- Easy to bolt in to factory location
- Strong, laser-cut, tig-welded and powder coated bracket
- Includes everything needed to install
- Nylon-covered stainless braided hose won't scratch finishes
- Low-profile 90° fittings for the oil cooler
B&M Oil Cooler Dimensions:
11" Wide
5.75" Tall
1.5" Thick
Part Number 70273
Includes:
(1) 5-Feet -8AN Hose
(1) B&M Oil Cooler
(1) STM Mounting Bracket (STM-EVO89-OCKBRK-S)
(3) M6 x 16 Stainless Allen Bolts
(6) M6 Stainless Flat Washers
(3) M6 Stainless Lock Washers
(3) M6 Stainless Nuts
(2) Vibrant -8AN 90° Swivel Fittings
(2) Vibrant -8AN to 1/2" NPT 90° Fittings
(2) Vibrant -8AN to M18 Fittings
(2) OEM Mitsubishi Washers
